Smith oil pressure gauge - how to reattach black plastic hose to fitting
BR021219
#1 Smith oil pressure gauge - how to reattach black plastic hose to fitting
Post by BR021219 » Tue Feb 12, 2019 7:49 pm
Hi all - I found this forum while searching for the best way to reattach the black plastic oil pressure line to the fitting. I own a 1964 e-type that I am hoping to race - but this question is for my other car which is a 1963 Mk2. The new gauge line we bought needs to be cut which requires reattaching the line to the fitting. Do I use heat? And if so, what is the best way to do that? Any ideas would really be appreciated.
Thank you.
- Bruce R
#2 Re: Smith oil pressure gauge - how to reattach black plastic hose to fitting
Post by mgcjag » Tue Feb 12, 2019 9:18 pm
Hi Bruce..welcom to the forum...lots of info here im sure you will enjoy....re oil pipe.....best way is heat the fitting and push onto the pipe....same as with nylon type fuel lines...Steve
#3 Re: Smith oil pressure gauge - how to reattach black plastic hose to fitting
Post by Heuer » Tue Feb 12, 2019 10:47 pm
Agree with Steve - heat the fitting ( probably in a vice) and then push on the pipe. Easy!
S1 OTS OSB; S1 FHC ODB
JJC
#4 Re: Smith oil pressure gauge - how to reattach black plastic hose to fitting
Post by JJC » Wed Feb 13, 2019 12:01 am
A cheap cigarette lighter works great.....used carefully, and an inch or two away. You will get a feel for it once you give it a try.
JC
BR021219
#5 Re: Smith oil pressure gauge - how to reattach black plastic hose to fitting
Post by BR021219 » Wed Feb 13, 2019 1:12 am
Steve, David, JC - thank you for the quick response. Your ideas are just what I was looking for. Great forum and I look forward to reading and sharing experiences about our great cars.
-Bruce and Lois
#6 Re: Smith oil pressure gauge - how to reattach black plastic hose to fitting
Post by christopher storey » Wed Feb 13, 2019 9:52 am
I am puzzled : what sort of oil pressure gauge is this ? the normal gauges are electric and have no pipe connected to them
JJC
#8 Re: Smith oil pressure gauge - how to reattach black plastic hose to fitting
Post by JJC » Wed Feb 13, 2019 11:42 am
Chris: This car must have changed over to a more accurate Smiths mechanical gauge, and ditched the useless, inaccurate electric gauge. It really is the way to go, and very easy to do. Of course, the new gauge fits in original hole, and basically looks exactly the same.
JJ
tim wood
#9 Re: Smith oil pressure gauge - how to reattach black plastic hose to fitting
Post by tim wood » Wed Feb 13, 2019 12:23 pm
It’s a shame they don’t make a gauge that reads to a max 60psi as per the original.
Didn’t stop me fixing a mechanical unit though.
Series 1 FHC purchased 40 years ago when I was young. Sold
Series 1 2+2 when the kids were small now sold
JJC
#10 Re: Smith oil pressure gauge - how to reattach black plastic hose to fitting
Post by JJC » Wed Feb 13, 2019 4:14 pm
After a while, you won't even notice the difference. Besides, in real-life , everyday driving in any E-Type, except on very cold start-up, its rare to see anywhere near 60lbs. As I recall, over many years with a V-12, I'm looking at between 10 and 35lbs all day long. Happy motoring !
JC
BR021219
#11 Re: Smith oil pressure gauge - how to reattach black plastic hose to fitting
Post by BR021219 » Wed Feb 13, 2019 4:32 pm
The gauge is a Smith mechanical - 0-100 lbs swing needle type.
JJC
#12 Re: Smith oil pressure gauge - how to reattach black plastic hose to fitting
Post by JJC » Wed Feb 13, 2019 4:56 pm
I was addressing Tim's concerns. Yup....mechanical gauge goes to 100.
MarkRado
Austria
#13 Re: Smith oil pressure gauge - how to reattach black plastic hose to fitting
Post by MarkRado » Wed Feb 13, 2019 7:25 pm
I changed over the dial to keep the original looks. You need to check real vs indicated pressure and learn by heart though. (in my case it is quite easy: 40 lbs indicated equals 4 bars real press, 20 equals 2 and so on)
1963 OTS 880436 - since 1988
Quattrofrank
Norway
#14 Re: Smith oil pressure gauge - how to reattach black plastic hose to fitting
Post by Quattrofrank » Wed Feb 13, 2019 7:50 pm
Depending on what have been done to the engine I belive you could exceed 60lbs
So its not useless to have that extra 40lbs on the gauge
JJC
#15 Re: Smith oil pressure gauge - how to reattach black plastic hose to fitting
Post by JJC » Sat Feb 16, 2019 10:46 pm
Yup....sometimes on cold start up, it will go to almost 70 lbs, but briefly, 60 lbs gauge has enough room to show that. Normal operation on any E-Type motor , 6 or 12, rule of thumb, once warm, is 10 lbs of oil pressure for every 100 revolutions (+ or - a few lbs).At idle, should indicate around 10 lbs of o.p. Cruising at 3000 rpm, around 25 to 30 lbs, depending on engine temperature. And so on...... Basically, 60 lbs gauge does the trick.
