I have just received our S1 3.8 OTS back following its IRS being renovated at Southern Classics at Twickenham. A superb job done and would fully recommend Steve and his team to fellow forum members. In terms of the work performed (as per photos below).
- IRS cage and major components bead blasted and powder coated.
- Vapour blasting of those components which have a natural finish.
- Replating where required.
- New Boge Shock Absorbers (painted BS633 with Girling stickers) and standard springs
- Differential seals replaced (no major internal work required) and painted to correct colour
- Coopercraft calipers fitted with bleed extension pipes for ease of future bleeding
- Handbrake mechanism overhauled
- New discs (edges painted to avoid corrosion) and pads
- New bushes and other wear/tear components
- New hub splines
- Reinstatement of original half-shaft shrouds and re-plated Cheney clips
IRS Renovation
#2 Re: IRS Renovation
Hi Phil...looks great....befor you install it have you considered the simple handbrake mod http://forum.etypeuk.com/viewtopic.php?t=6170 Steve
#3 Re: IRS Renovation
To be honest, I hadn't since I had not had any issues with the handbrake's effectiveness previously. The IRS is now back in the car so I'll see how it goes in the coming months.mgcjag wrote: ↑Sat Feb 16, 2019 9:51 amHi Phil...looks great....befor you install it have you considered the simple handbrake mod http://forum.etypeuk.com/viewtopic.php?t=6170 Steve
1964 S1 3.8 OTS
1964 S1 3.8 OTS
#4 Re: IRS Renovation
A newly restored IRS always looks very nice.
FWIW what did they charge you?
