Yes but wouldn't you have had the fire whether the pipes were wrapped or not? If hydraulic fluid sprayed in the direction of the exhaust pipes it would catch fire.
+1 for silicone brake fluid.
Insulation on exhaust hoses
#22 Re: Insulation on exhaust hoses
No one can be sure if the fire had started anyway. But remember the pipes are hotter if they are wrapped. And the wrap soak up the oil. Its like a flambeau( correct word?)
My engine was not what I call hot when this happened either. I was idling in a traffic jam for while when this happened.
Mats
1966 S1 OTS
1966 S1 OTS
#23 Re: Insulation on exhaust hoses
This is another argument for a solution that keeps the surface temperature of the pipes lower. Ceramic coatings (which can be applied both to the interior and exterior of a header (or manifold or pipes) does exactly that.66an wrote: ↑Fri Apr 19, 2019 9:34 amNo one can be sure if the fire had started anyway. But remember the pipes are hotter if they are wrapped. And the wrap soak up the oil. Its like a flambeau( correct word?)
While not a guarantee, obviously there are circumstances where the surface temp is high enough to start a fire, these situations are fewer.
