Welding 3.8 block?
#1 Welding 3.8 block?
I seem to have a problem with one of the water passages in the block:
Does anyone know how weldable is the iron on these blocks?
Or are there other modern methods that are better?
Tadek
Tadek
Tadek
Jaguar XK120 OTS
Austin-Healey 100 BN2
Jaguar XK120 OTS
#2 Re: Welding 3.8 block?
Common problem. My machinist grinds them out, brazes them and them cuts them back to shape.
#3 Re: Welding 3.8 block?
Thanks - is there a chance you can find out what does he use for brazing??..
Tadek
Tadek
Tadek
Jaguar XK120 OTS
Jaguar XK120 OTS
#4 Re: Welding 3.8 block?
Nickel bronze rod.
#5 Re: Welding 3.8 block?
Many thanks - I understand te block has to be preheated?
Tadek
Tadek
Tadek
Jaguar XK120 OTS
Jaguar XK120 OTS
#6 Re: Welding 3.8 block?
I don't know much about the process I'm sorry. I just pay them to do it.
#7 Re: Welding 3.8 block?
The blocks are cast. Cast iron can crack. It would be heated I'd imagine or the local heating caused by the brazing may cause a crack to form. A job for an expert who knows what they are doing or you stand a good chance of wrecking the block all together. Not something do do in your garage!
#8 Re: Welding 3.8 block?
you are right.. I have to find the right guy :-).
Tadek
Tadek
Tadek
Jaguar XK120 OTS
Jaguar XK120 OTS
#9 Re: Welding 3.8 block?
Give Stitchweld in Burton on Trent a call. They can repair just about any kind of damage on a large range of parts and materials.
Brian there is a magician with metal. He repaired my sump and he did appear on Car SOS where he repaired an engine block for Fuzz.
'78 Land Rover Series 3 109
