engine swap
bill addison
#1 engine swap
Post by bill addison » Tue May 14, 2019 12:37 pm
Hi all
I have bought a1962 series 1 ,the previous owner fitted a 4.2 and I want to put it back to the original 3.8. .Which way would you go to make the swap . Buy a rebuilt 3.8 or strip the 4.2 for bits
From what I have read the heads are the same ? the 4.2 was a bigger bore, the stroke was the same as a 3.8
would this mean the crank shaft is the same ?. All I would need is a 3.8 block and pistons ?
Any help appreciated
1954Etype
#2 Re: engine swap
Post by 1954Etype » Tue May 14, 2019 2:02 pm
Bill,
if it were my car (and it was driving ok) I'd wait until a complete 3.8 engine became available. You will then have a complete 4.2 engine to sell.
Angus
Angus 67 FHC 1E33656
bill addison
#3 Re: engine swap
Post by bill addison » Tue May 14, 2019 7:37 pm
The car is being stripped for a full re build
bill addison
#4 Re: engine swap
Post by bill addison » Thu May 16, 2019 6:03 am
Has anybody advice on shot blasting or dipping ? what is the best way to get back to bare metal
#5 Re: engine swap
Post by christopher storey » Thu May 16, 2019 6:46 am
Certainly not dipping - the chemicals used are virtually impossible to get out of seams and have a habit of coming out after a year or two and ruining your new paintwork ! Be very careful with blasting also : the choice of medium is vital, as is the pressure used, as it is very easy to distort irreparably the largely unstressed larger panels. Walnut shell is probably the best bet
MarkRado
Austria
#6 Re: engine swap
Post by MarkRado » Thu May 16, 2019 12:06 pm
Soda blastng, but only removes paint, not rust
1963 OTS 880436
ChrisC
#7 Re: engine swap
Post by ChrisC » Thu May 16, 2019 12:16 pm
I had my FHC body shot blasted by a company familiar with stripping back car paint and overall had a positive experience. One thing I would mention is that the blast media gets everywhere and even years later I find little deposits that have finally worked their way out of crevices.
The reason for mentioning this is you have to be very careful when painting the car as the paint gun *could* blow unseen blast media onto the paint.
I am not sure I would do it again but it was cheap, quick and efficient.
1964 FHC 4.2
#8 Re: engine swap
Post by rswaffie » Thu May 16, 2019 4:48 pm
Hi Bill,
I had reservations about oven baking/chemical dipping and blasting so went down the DIY route and used a heat gun and scraper which took it back to the red oxide. I then used strip discs on a grinder that took it back to metal and the strip discs (plastic mesh impregnated with grit) left a nice surface.
The awkward nooks and crannies I just used paint stripper.
Satisfying and saved a large chunk of money in the process.
bill addison
#9 Re: engine swap
Post by bill addison » Thu May 16, 2019 6:55 pm
I have been to Heratige-Classics in Middlesborough today and he said much the same as you guys .
His advise was paint stripper , might need an extra pair of hands .
