S3 gearbox swap
#1 S3 gearbox swap
Hi all,
I'm thinking of swapping my 3sp g/b with O/D for an auto box for ease of driving !.My wife has left knee problems and I have fused and arthritic left ankle problems.
Various suggestions have been made amongst them using a 4HP 24 with 22 guts?!
Would anyone like to chip in .?...please
Peter {XKE V12HE efi}
XKRS
RR Phantom 3 1937 Sedanca de Ville.
XKRS
#2 Re: S3 gearbox swap
Whitehouse Autos offer these conversions. Might be worth talking to them. http://gwautos.com/
Bob
Bob
Bob
'71 S3
'71 S3
#3 Re: S3 gearbox swap
Thanks Bob I had thought of them.
The difficult bit I understand is the bell housing as the front of a 4hp24 is not instantly compatible with the back of a v12.
Someone somewhere will have done i, I had hoped to do the majority of work " in house", that was the plan....you know what happens to plans!!!!
XKRS
XKRS
#4 Re: S3 gearbox swap
Hi..Whats your name....not really sure on the S3 but you might have to alter the tunnel area as well.....in the S2 the tunnel was wider on the auto box models.....Steve
#5 Re: S3 gearbox swap
Sorry
Pete . The bodywork I'm told is a maybe?!
XKRS
XKRS
#6 Re: S3 gearbox swap
Hi Pete,
Autos were much more popular in the US. Have you tried searching/posting on jag-lovers? In addition to the etype forum they have a V12 engine specific forum here https://forums.jag-lovers.com/c/v12-engine.
Good luck,
Bob
Good luck,
Bob
Bob
'71 S3
'71 S3
#7 Re: S3 gearbox swap
Thanks Bob
XKRS
XKRS
#8 Re: S3 gearbox swap
Well,.....
That's the end of that then....my other half..maybe3/4 has pronounced that the gearbox can stay as a manual !!!!!!!!@@@&&£££???!?
So, I'll be staying with the manual OTS in blue, but apparently with a hard top on ASAP for bad weather.!
I did have a thought about the H/T though, everyone talks of the marks that can be caused around the back of the seat when fitting...
Has anyone made a rail/strip/thingy to let the H/T sit on, rather than tha actual painted surface of the body?
XKRS
XKRS
#9 Re: S3 gearbox swap
Pete Wrote:
I use the clear wrap material that's used to protect the leading area paint of vehicles, typically race cars.
Hello Pete,I did have a thought about the H/T though, everyone talks of the marks that can be caused around the back of the seat when fitting...
#10 Re: S3 gearbox swap
bill
Cracking idea
how wide did you make it to survive?
Cracking idea
XKRS
XKRS
#11 Re: S3 gearbox swap
Thanks to everyone that replied but …..
SHE {my nearest and dearest} has now declared that she can manage the manual box with the aid of a booster cushion !!!!!
so all is now past history on the auto box swap… thats a few more hours i have to spare…suggestions please
XKRS
XKRS
#12 Re: S3 gearbox swap
Hi Pete,
Sorry can't help with the sore head, but have you thought of adding a servo to reduce effort on the clutch pedal. A friend of mine added one to his TR4 to make it easier for his daughter to drive. I can ask him which unit he used if you are interested. This one https://www.carbuildersolutions.com/uk/ ... r-assister for instance is less than 6" diameter, gives a 2:1 boost and would probably fit behind/below the battery where the charcoal canister was located on early North American Market S3s.
Bob
'71 S3
'71 S3
#13 Re: S3 gearbox swap
Bob, that's an idea but I'm not sure if I've got anywhere to put it in the s3 .
I tried to get some info from coachbuilder solutions but they are not in stock!
I'll ask the driver
I've just replaced the antirolbar bushes with "polybushes" made a bit of difference when dry -- fewer "squeaks "
Next bit to do is replace the seats with retrimmed XJS type ...but they're a bui wider and they need to have a bit " sculpted out of the back/side edge to cope with hood metalwork...watch this space...anybody den this?..
Pete.
I'll ask the driver
Pete.
XKRS
XKRS
#14 Re: S3 gearbox swap
MX5 seats are a favourite on this forum. There's a lot of information here about the conversion and there are lots of people re-covering them to match whatever you want.
'78 Land Rover Series 3 109
