#1 satin or gloss black
Posted: Tue Jun 25, 2019 7:35 pm
by adam
Hi is the steering column adjuster gloss black or satin and the indicator stalk cowl satin or gloss black.On a 3.8.
Thank you Adam
#2 Re: satin or gloss black
Posted: Tue Jun 25, 2019 9:47 pm
Semi gloss, which is half way between gloss and satin. If you can't source semi-gloss go for Satin.
#3 Re: satin or gloss black
Posted: Tue Jun 25, 2019 10:25 pm
by Turnip
You can get quite a nice shiney-but-not-glossy effect if you use satin paint and then rub it down with Solvol Autosol. I can't say if it's technically the correct look, but it seems OK on mine.
#4 Re: satin or gloss black
Posted: Wed Jun 26, 2019 5:08 pm
by adam
Thanks for the info on original finish as I had seen gloss and satin finish on different cars.
Thank you Adam
