Diff oil change & flush???
Topic author - Posts: 41
#1 Diff oil change & flush???
Having removed the diff plug & filler successfully, I'm wondering should I flush the diff housing with something before adding the new oil. The oil appears to be relatively clean but the car has sat for a couple of years before I acquired it. What would be a suitable flushing product??
Ross
1972 Series 3 E Type 2+2
1972 MGB GT
1965 Mini Cooper
https://rossjohnsonphotography.zenfolio.com/
1972 MGB GT
1965 Mini Cooper
#2 Re: Diff oil change & flush???
If you drove the car recently, even only a mile, I would not flush because of removing proper oil from the limited slip clutch packs and coating the clutches with a non- lubricant. Just fill with the correct fluid including limited slip additive.
