Scuttle top casing cover
#1 Scuttle top casing cover
Hi all,
I just remade my scuttle top casing in aluminium and would like to know were to buy the trim cover.
Mich
Mich
Michel
#2 Re: Scuttle top casing cover
Hi Michel,
If you mean item 26 in the pic , I got mine from BAS. It needs to be heated up and moulded round the metal or in your case aluminium panel. I didn't fancy doing it myself so sent the panel to Jack at BAS to do, however there are those on here who have done it themselves. Richard rswaffie springs to mind.
If "scuttle top casing" and" trim cover" don't refer to a dash top cover then just ignore the above.
#4 Re: Scuttle top casing cover
Hi Simon,
So I ignore ...
The parts I refer are the pannels under dashboard but the Jaguar book call them "scuttle top casing assembly".
I need to cover them as near as the original for I think the original trim is now no longer available.
Mich
So I ignore ...
Mich
Michel
#6 Re: Scuttle top casing cover
I'll try.
Thanks Simon
Thanks Simon
Michel
#7 Re: Scuttle top casing cover
Hi Michel,
I think the early ones were aluminium covered with vinyl (leathercloth) similar to the door cover vinyl.
The later ones were made of Millboard.
Unfortunately I dont know what date they changed.
#8 Re: Scuttle top casing cover
Hi Paul,
Mine where covered with Millboard. I tryed to covered the new one with vinyl but it's thiker and so more difficult to fit.
If I don't find, I let them with vinyl.
Mich
Mich
Michel
#9 Re: Scuttle top casing cover
Hi Michel,
The Millboard does not have a covering as such, the millboard itself has a textured face.
https://www.martrim.co.uk/car-trimming- ... lboard.php
#10 Re: Scuttle top casing cover
I fitted just the mill board pieces, as said they are textured (also not visible). The covers are quite chunky with a traditional flax / hemp insulation and black heavy finish. These are still on the shelf and will probably never be fitted.
Tony in Devon
#11 Re: Scuttle top casing cover
I ordered some thin vinyl from Martrim.
We'll see if it's near the original.
mich
mich
Michel
#12 Re: Scuttle top casing cover
For those who would have any interest, I ordered " Vinide Leather Cloth" From Martrim to do the job.
Very thin, 1/32" ( 0.8mm) it's a very good product.
Prefer neoprene in spray to glue it on the aluminium you'll avoid some acumulations of glue.
Mich
Mich
Michel
