Hi all,
I am putting new bearings etc in my all syncro gear box. I dismantled the syncro assembly and didn't note where short and long springs fit in syncro hub. In my manual, it doesn't tell where short or long spring fits. Can someone help me identify where each spring goes in syncro hub.
Thanks Chris.
4 speed all syncro gear box
#2 Re: 4 speed all syncro gear box
Hi Chris,
If you look at the diagram on the barratt site , you can look at the images of c27491 and c24181. The c24181 (goes under the detent ball) looks a heavier spring . This is only an opinion but I am sure someone will be able to prove or disprove this theory .
Greg
Greg
#4 Re: 4 speed all syncro gear box
Thanks I will have a look at there site.
Chris
Chris
#5 Re: 4 speed all syncro gear box
Hello Chris,
I can confirm that the shorter, heavier spring goes with the ball bearing.
