#1 Function of L position on BW8 automatic gearbox
Posted: Wed Dec 04, 2019 7:48 pm
by ysmalkie
I am trying to diagnose my friend's problems with his BW8 gearbox. I am not a fan of automatics, and I have a feeling it works differently than the more modern units.
I understand L means "Lockup" not "Low", but how does it function?
I presume D1 allows to drive in 1st, 2nd and 3rd gear and is a equivalent of a modern "D" position?
I understand D2 allows you to drive in 2nd and 3rd gear - what would you use it for??
However I do not understand what's the L function:
- can I select it from D1 or D2?
- does it always downshift from 3rd gear to 2nd?
- does it always downshift to 1st when I am in 2nd gear?
The manual uses 3 throttle positions:
- Minimum
- Full
- Kickdown
What's the difference between "full" and "kickdown"?
And what is the meaning of "accelerator at the detent"??
Being Polish, I should polish up my English...
Mant thanks for help..
Tadek
#2 Re: Function of L position on BW8 automatic gearbox
Posted: Thu Dec 05, 2019 10:15 am
Hi Tadek....have you seen this booklet...available on ebay etc...full operating details are in there..its a great littlr book worth getting...here are a few photos ..should help you...Steve
#3 Re: Function of L position on BW8 automatic gearbox
Posted: Thu Dec 05, 2019 11:31 am
by ysmalkie
Many thanks - exactly what I needed!
