Fuel sender connection at dash.
ollieoscarsid
#1 Fuel sender connection at dash.
Post by ollieoscarsid » Mon Feb 03, 2020 6:51 pm
Hi, fitting a new loom to my 63 fhc lhd. I think it’s auto sparks, but came via Sng Barratt, the left hand rear body loom has a green/brown wire for the fuel sender. I can’t find it’s mate on the dash loom, everything else is fine just a missing green/brown. Any thoughts appreciated. Chris.
1963 S1 opalescent silver blue
MarkRado
Austria
#2 Re: Fuel sender connection at dash.
Post by MarkRado » Mon Feb 03, 2020 7:32 pm
According to the wiring diagram, greenbrown (GN) is allocated to the flasher. Greenblack (GB) should be the wire from fuel sender to instrument. Some years ago a loom from autosparks we ordered for a P5 Rover was missing a wire altogether by the way.
1963 OTS 880436
ollieoscarsid
#3 Re: Fuel sender connection at dash.
Post by ollieoscarsid » Mon Feb 03, 2020 10:03 pm
Apologies, I meant the reversing light wire (late night/lots of wires :scratchheadyellow: ) there is a short green/brown (GN) from the flasher unit to the indicator switch, but this is separate.
It’s odd because I have GN wires in both side looms when I only need one, but can’t find a home for either. There is a 2’ long Separate lead G/GN to go from dash loom to rev switch, but only a home for the green. The GN from either side loom is too far away. There’s either a wire missing or I’m doing something daft. ( almost certainly the latter)...
#4 Re: Fuel sender connection at dash.
Post by abowie » Tue Feb 04, 2020 8:26 am
The Autosparks looms do this. I assume it's easier than making special LHD vs RHD ones.
