Hi all,
Following my earlier query, I assume the bolt is non-standard and the metal washers are 'packing'.
The banjo itself has a flat face on one side (facing the bolt head); the other side is recessed sufficiently to accept the second fibre washer (except that the second fibre washer is redundant as the pump body has the retaining groove for the rubber o-ring)
Can someone please advise whether the banjo should have a flat face on both sides?
John L
Banjo union to fuel pump
#2 Re: Banjo union to fuel pump
Hi John....please try to add your car model in the signature area with your name....note that there are various different models of pum/banjo,s available... so the best advice i can give is to call https://burlen.co.uk/ they are the manufacturers explain the situation im sure you will get tbe best advice....Steve
