Boot springs
Bernie2015
#1 Boot springs
Post by Bernie2015 » Sat Mar 28, 2020 1:18 pm
Well I've got the bugger off - question is how to replace the broken springs and reassemble?
Bernie 1966 S1 OTS
#2 Re: Boot springs
Post by mgcjag » Sat Mar 28, 2020 1:37 pm
Bernie...the search function works well....plenty of info here re springs...also similar topics below...Steve
Bernie2015
#3 Re: Boot springs
Post by Bernie2015 » Sat Mar 28, 2020 3:22 pm
Found some good info thanks Steve - been putting this off for a while!
Bernie 1966 S1 OTS
ianfey
#4 Re: Boot springs
Post by ianfey » Fri Aug 14, 2020 9:40 am
Wear thick leather gloves.the springs are like razor blades. Good video on YouTube where a guy made up a jig which made it look easy
#5 Re: Boot springs
Post by Heuer » Fri Aug 14, 2020 9:45 am
From our Knowledge Base:
Boot Spring Replacement Guide: https://www.dropbox.com/s/9v1yz7d2fflvb ... 1.pdf?dl=1
Boot Spring Replacement Guide (Dick Maury): https://www.dropbox.com/s/sue9kcr2wsj08 ... 2.pdf?dl=1
Boot Spring Replacement Guide: https://www.dropbox.com/s/g4gepgl9vas91 ... l.pdf?dl=1
S1 OTS OSB; S1 FHC ODB
Bernie2015
#6 Re: Boot springs
Post by Bernie2015 » Fri Aug 14, 2020 10:35 am
Great thank you will give it a go at some point keep putting it off!!
Bernie 1966 S1 OTS
