Good question.
I didn't do the maths *, but which ever charts you look at, at the recommended NGK tightening figure of 30Nm or 22 ft.lbs for 14mm plugs, it appears that we are already putting a figure of between 2.100 lbs and 2.800 lbs stretch on what is effectively a bolt.
I think that suggests we apply a one-tonne pull on the plug thread every time we tighten it.
So I'm happy with it, although lifting on just one might feel like tempting providence !
* - I cheated by approximating around the 9/16" x 18 TPI shown on these tables, other ones and tabulators I looked at seemed to be of that order of magnitude too.
Engine hoist load leveller
#41 Re: Engine hoist load leveller
#42 Re: Engine hoist load leveller
The most horrible aspect of these cheapo engine-cranes, and many other unspeakable hydraulic devices from the Far East, is the fact that the bleed or lowering valve is generally operated by the end of the operating arm.
I see that nothing much has changed in 40 years since my first jack ; you are expected to get this slotted tube over the T-piece, and adjust the bleed by rotating a bit of 20mm pipe two feet long.
They must really think we're stupid. Really stupid.
Here's an easy tweak.
Remove the T-valve and put a bolt in its place to stem the leak.
I wasn't wholly confident how the nose of this did the business, and it was surprisingly well machined in comparison with the rest of the junk construction, so I elected to modify it rather than make another, longer, one.
Knock out the cross-piece, and bore a 5mm hole down the valve about 6mm deep.
Turn a nose on a similar bolt - I used an M10 socket-screw with a bit of parallel shank.
Push the two together with a bit of flux and Sif-bronze them together.
Add a suitable knob.
Should be a million times easier to operate, and also easier to dose more gently.
#43 Re: Engine hoist load leveller
Rory, as ever a lovely well executed mod to something that's been annoying many of us for years but in fairness to our Far East suppliers, I suspect that all they did was copy a poor bit of UK or European design on a cheap piece of hydraulics from 50 years ago.rfs1957 wrote: ↑Wed Jul 01, 2020 8:34 pmThe most horrible aspect of these cheapo engine-cranes, and many other unspeakable hydraulic devices from the Far East, is the fact that the bleed or lowering valve is generally operated by the end of the operating arm.
1969 Series 2 FHC
1969 Series 2 FHC
#44 Re: Engine hoist load leveller
That’s the thing about Rory’s projects.
I always end up thinking “why the hell have I put up with that over the decades...”.
Series 2 FHC 1970
1R 20607
1R 20607
