Should there be a hole here?
Stevejaguar
#1 Should there be a hole here?
Post by Stevejaguar » Tue Jun 30, 2020 8:29 am
Series 1 2+2.
Hi there is a hole at the top of the windscreen pillar on my car. The photo is of the drivers side (UK). The other side hole has been filled. I ask because part of the edges of the hole appear to be straight as though metal was cut to give a rectangular hole.
#2 Re: Should there be a hole here?
Post by christopher storey » Tue Jun 30, 2020 9:01 am
I'm afraid not. The pillar should be unperforated throughout its length
Stevejaguar
#3 Re: Should there be a hole here?
Post by Stevejaguar » Tue Jun 30, 2020 10:12 am
Thanks Christopher, I half suspected that.
I have had a dig around in there this morning and found the end of a small ( 4mm outside diameter) rubber pipe.
Better get welding this afternoon.
#4 Re: Should there be a hole here?
Post by christopher storey » Tue Jun 30, 2020 11:31 am
The presence of a tube is unusual, unless your car is one of the very rare ones with a factory metal sunroof
Stevejaguar
#5 Re: Should there be a hole here?
Post by Stevejaguar » Tue Jun 30, 2020 12:23 pm
Hi, no sign of it ever having had a sunroof. I will investigate the tube further if I can get at it.
tim wood
#6 Re: Should there be a hole here?
Post by tim wood » Tue Jun 30, 2020 12:30 pm
The tube isn’t the remains of a roof mounted aerial by chance?
#7 Re: Should there be a hole here?
Post by rswaffie » Tue Jun 30, 2020 12:31 pm
Could it be that a p/o has installed his own drain tube? Where does the other end of the tube go?
#8 Re: Should there be a hole here?
Post by 1954Etype » Tue Jun 30, 2020 12:39 pm
Bet it is the remnants of the roof lining side trim.
#9 Re: Should there be a hole here?
Post by rswaffie » Tue Jun 30, 2020 12:47 pm
Good point!
Stevejaguar
#10 Re: Should there be a hole here?
Post by Stevejaguar » Tue Jun 30, 2020 8:17 pm
Hi and thanks for the suggestions. I am thinking that it is part of the headlining trim. The tube is only about 2mm bore and 4mm OD so not much use for anything.
Thanks for the responses. I have another topic on here 'loft insulation ' If you would care to look at that one please.
