Vacuum non return valve failure
#1 Vacuum non return valve failure
Has anyone else experienced issues with the vacuum non return valve that sits on the reservac tank? Mine seem to last a couple of years max before some movement develops between the upper and lower halves, and it starts leaking air into the inlet. I must be on my 3rd by now. They’re all marked Trico, so not dodgy pattern parts. I’m tempted to see if I can re-seal one, maybe with some gasket compound. Tapping at the little tangs that hold the halves together to tighten the joint doesn’t seem to be a long term fix.
Tom
1970 S2 FHC
1970 S2 FHC
#2 Re: Vacuum non return valve failure
Clean it well and then coat the whole thing with 2 part epoxy. That should seal it permanently till the diaphragm fails.
Geoff Allam
#3 Re: Vacuum non return valve failure
That’s a good idea, thanks.
Tom
1970 S2 FHC
1970 S2 FHC
