So I contacted the UK supplier and they have replied to say that I do indeed need to cut it down to fit? ( I guess this is an after market seal then and not advertised as such!). I have ordered an OEM seal to compare and fit, all being well.
Thanks for the advice Peter, I wasn't sure if the twin ribs sat in the sump or up against the journal/carrier but you have answered my query (twin ribs - upper most). Strangely the seal naturally curves with the thicker twin grooves - bottom most. The photo was for length reference but good spot!
Would you recommend a smear of sealant along the twin grooves prior to fitment, or let it do its thing??
PeterCrespin wrote: ↑Tue Sep 15, 2020 9:07 pm
Cork is for wine. Nitrile rubber is for petrochemicals and crumbles not at all.
Agreed! The cork seal was fitted by VSE back in 1999 when the car was restored (46K miles - now 50K). It'll be more when I get it to E-60 next year from Highlands!
Thanks again for all your replies, very much appreciated.
