Air filter drum support bracket
Topic author - Posts: 116
#1 Air filter drum support bracket
Hi guys has anyone got a picture they could send me of the air cleaner support drum bracket underneath that the drum rests on. Mine was missing so trying to fit one but can’t see where it bolts on to as new panels in
Thanks harvey
Thanks harvey
#2 Re: Air filter drum support bracket
Not exactlyvwhat you want but may help.....have you searched here on the forum. ...Steve http://forum.etypeuk.com/viewtopic.php?t=8575
#3 Re: Air filter drum support bracket
Hi Harvey.
If you have new toe boards fitted if you look inside the car you will see a nut insert that is not used by the engine frame fixing bolts but its not been drilled through the panel.
This is what you need, just drill through from inside the car first with the tapping size drill & then open up very carefully from the out side but only for the panel thickness do not drill out the thread.
This is the mounting for that bracket , there should be one punched in the sill end plate already.
Neal.
Neal.
#4 Re: Air filter drum support bracket
I have some photographs for you Harvey but seem to have lost the method of posting them.
Anyone can help me with my dimness.
thanks
Ash
thanks
Ash
Series 2 FHC 1970
1R 20607
1R 20607
#5 Re: Air filter drum support bracket
Hi Ash......once you type your post at the bottom of the page you should see highlighted...add image to post...select this then select your image....Steve
#6 Re: Air filter drum support bracket
Thanks Steve - I am sure it is me but that did not appear to be there earlier.
Anyway - there now so a couple here that may help Harvey.
cheers
Ash
cheers
Ash
Series 2 FHC 1970
1R 20607
1R 20607
#7 Re: Air filter drum support bracket
Thank you very much guys for all the info, Great help.
That’s perfect, pictures are brilliant.
I can crack on now with that. Till the next thing lol
harvey
harvey
#8 Re: Air filter drum support bracket
Bob F
69 S2 E-type OTS LHD
#9 Re: Air filter drum support bracket
Interesting in that I also thought that the air cleaner bracket should be painted black. But should the vac tank also be black ? Mine has been silver for the last 30 years.
#10 Re: Air filter drum support bracket
The tank should definitely be black with "Trico Reservac" stencilled on it. See link belowStevejaguar wrote: ↑Wed Nov 18, 2020 2:12 pmInteresting in that I also thought that the air cleaner bracket should be painted black. But should the vac tank also be black ? Mine has been silver for the last 30 years.
http://forum.etypeuk.com/viewtopic.php? ... 72e35a5b4
1964 S1 3.8 OTS
1964 S1 3.8 OTS
#11 Re: Air filter drum support bracket
The Reservac stencil was only used up until late 1965 IIRC so correct if your car predates that.
S1 OTS OSB; S1 FHC ODB
