Hepolite Ring Set # 2555
mxke
#1 Hepolite Ring Set # 2555
Post by mxke » Tue Dec 08, 2020 1:47 am
I was digging thru some parts I have and came across this ring set.
Would these be for a 3.4 litre engine?
Thanks,
Mike
mxke
#2 Re: Hepolite Ring Set # 2555
Post by mxke » Sat Dec 12, 2020 4:26 pm
Someone must know!
#3 Re: Hepolite Ring Set # 2555
Post by bitsobrits » Sat Dec 12, 2020 5:28 pm
That bore is consistent with both the 3.4 and 2.4 liter versions of the XK engine. But as to ring thickness and count, and therefore compatibility with specific pistons, I think you will need to find some Hepolite documentation to give you a definitive answer as to which specific application they are for.
'65 S1 4.2 FHC
paulsco
#4 Re: Hepolite Ring Set # 2555
Post by paulsco » Sat Dec 12, 2020 5:32 pm
Hi Mike,
All I can tell you from my Mk2 manual is that 3.2677 is the size of the cylinder bores of the 2.4 and 3.4 Mk2.
The 3.8 is 3.4252.
Hepolite are not standard fit pistons, at least not on the Mk2, Brico is.
paulsco
#5 Re: Hepolite Ring Set # 2555
Post by paulsco » Sat Dec 12, 2020 5:36 pm
Sorry Steve; you answered this while I was still typing :bigrin:
mxke
#6 Re: Hepolite Ring Set # 2555
Post by mxke » Sat Dec 12, 2020 5:50 pm
Thank you!
Mike
