Oil filter bolts
#1 Oil filter bolts
S 1 4.2 .Hi I am just fitting the oil filter housing and I noticed a bolt hole at the centre bottom on the block with no corresponding hole in the fitting . Is this OK ( it has the spin on conversion fitted which I took off and checked behind)
S1 4.2 RHD Bryan
#2 Re: Oil filter bolts
There should be a slotted grub screw in the spare tapped hole to blank it off --.
Steve3.8
64 3.8 fhc, 67 4.2 fhc
