servo fitment puzzle??
NorfolkJohn
#1 servo fitment puzzle??
Post by NorfolkJohn » Thu Jan 14, 2021 8:37 pm
Hello, once again working on rebuilding the series 3 car. We are trying to get the servo on the bulkhead - but the frame seems to be in the way.. Is there a trick to fitting it? Don't want to remove the frame. Do you disassemble the servo - or there another way .. Engine is in already - no heater in place.. The servo looks as though it would split .. is this the way ?? Any advice gratefully received..
#2 Re: servo fitment puzzle??
Post by mgcjag » Thu Jan 14, 2021 8:58 pm
Assuming you have the correct servo it should fit in without any major work......full step by step detailed instructions to remove and refit in the Jag S3 service manual.....Steve
madjack4
#3 Re: servo fitment puzzle??
Post by madjack4 » Thu Jan 14, 2021 11:37 pm
Hi i had same problem fitting my servo it does go in but its a puzzle it took me quite a while trying it different ways to get it in i walked away for a pot of tea when i came back it went straight in keep at it it will go in
`Regards
NorfolkJohn
#4 Re: servo fitment puzzle??
Post by NorfolkJohn » Fri Jan 15, 2021 9:18 am
Thanks for the input ! it seems very close to fitting in - however there is a bracket on the frame tube - only small but just in the wrong place to allow it to go in easily. However emboldened by your comments and more tea - will have another go.. Cheers
#5 Re: servo fitment puzzle??
Post by politeperson » Fri Jan 15, 2021 11:54 am
It goes in from underneath without too much spillage.
The bracket you mention probably secures the end of the cylinder on the servo to the frame.
Slacken this off first, dont tighten it until the servo is loosely in place.
Then tighten them all up together.
James
L.J.K. Setright was right.
Joes66
#6 Re: servo fitment puzzle??
Post by Joes66 » Fri Jan 15, 2021 4:30 pm
Yes the servo goes in from below
The series 3 servo is bigger than the series 1 and 2 and won't go in from the top
You have to remove the splash panel thats underneath the servo
The end if the servo has a thread in it for the end mounting bracket that goes round the frame
Joe
1969 series 2 2+2
