The car a S1 2+2 has been completely rebuilt, engine And box out engine rebuilt, gear box stripped and all that seemed obvious was a new speedo drive shaft, the rear main tail bearing and obviously the rear main seal.
After 1k miles no leaks all perfect, then oh no a few drips of oil on the garage floor.. closer inspection proved it was coming from the tail end of the box, Hoping it was a leak from the speedo drive I removed it fitted a new O ring put it all back .. but yes you guessed still the same.
Took the centre console out looked through the inspection plate and maybe just a tiniest amount looked a little wet.
Anyhow long story short changed the seal put it all back still leaking!!!
So annoying! Any ideas guys, checked the breather pipe that was clear, and the prop shaft flange was as bright as a new pin when inserted in the box, it was rubbed down with 400 grit wet n dry and didn’t even chance spraying it.
Any help
Thanks guys
