Synchro mechanism
#1 Synchro mechanism
Hi.
Manual gearbox 1973 series 3.
Rebuilding gearbox, new bearings etc. Worn layshaft and reverse shaft also needs replacing. Gearbox were making rumbling noises.
And gear stick moved forward when accellerating and rearward when decellerating. Have some sugestion that it might be worn synchro hubs. The syncro hubs, synchro rings & operating sleeves are dismanteled, but how can I determine wether they are good / worn / worn out? What to look for?
The box was shifting just fine, no crunches, grinding.
The hubs looks good to me, same with sleeves. There are some wear on synchro rings «teeth». But enough to cause any symptoms? I think ring for first is showing most wear.
See pictures, hopefully good enough? Operating sleeve: Screwdriver pointing at one of the teeth having three detent grooves.
Thanks. Rgds Harald
Thanks. Rgds Harald
#2 Re: Synchro mechanism
Hi, if you go and watch on YouTube a channel called garage time, a guy there is doing a Porsche 356 gear box with a similar issue on a recent video and goes into details of how to check and fix it.
https://www.youtube.com/watch?v=AplAVLZ0qw0&t=44s
#3 Re: Synchro mechanism
Thank you. Chekced it out. It reminded me that I also have to look at the top lid, checking springs, balls, detents etc. Also found a video on what to look for on the synchro hubs. After wathing that one I think mine is fine - for now at least.
Harald
Harald
#4 Re: Synchro mechanism
I am happy I was able to be of some help and hope things will go well with yours
#5 Re: Synchro mechanism
Everything looks fine. On reassembly I think it would be beneficial if possible to rotate the outer sleeves to a different position so that the detent balls run on new unwarn teeth.
Randall Botha
'64 3.8 fhc & '51 Mk 7
#6 Re: Synchro mechanism
Moving slowly ahead. New layshaft, reverse shaft and ballbearings obtained. Waiting for a few hundred roller pins.
Reverse shaft, from packing looks like NOS. But had expected it to be shiny but it is matt black. Supposed to be like this? ( pickture ).
Randall, that idea occured to me. But the detent balls shall be in line with the operating sleeve teeth having three detent grooves. Maybe possible to grind new detent grooves in another position. If worn, could be reason for gear lever moving forward / rearward with accellerator pedal.
Rgds Harald.
Rgds Harald.
#7 Re: Synchro mechanism
Norton Wrote:
That's what the original Reverse Idler Gear Shaft should look like. The shaft was machined to finished size and then heat treated, probably Nitriding, without a further finishing operation.
The Reverse Idler Gear Shafts I manufacture are case hardened and cylindrical ground after case hardening and appear as shown in the following picture. Notwithstanding that minimal distortion occurs with Nitriding, the advantage of finish grinding after heat treatment, is that all distortions is eliminated in the finishing operation.
Hello Norton,Reverse shaft, from packing looks like NOS. But had expected it to be shiny but it is matt black. Supposed to be like this?
#8 Re: Synchro mechanism
Bill,
Do you sell your reverse idler shaft outside of Australia? I need to procure one (Dallas, Texas area). Perhaps you could PM me?
Thanks, Eric
Thanks, Eric
Eric
#9 Re: Synchro mechanism
Bill thanks.
And as Eric, is it possible to obtain your rev shaft outside Australia?
Rgds Harald, Norway
Rgds Harald, Norway
#10 Re: Synchro mechanism
Harald,
Do you recall where you purchased the factory reverse idler shaft shown in your photos?
Thanks, Eric
Thanks, Eric
Eric
#11 Re: Synchro mechanism
Denis Welch does a lot of E type parts....they have this listed but no photo https://www.bighealey.co.uk/index.php?r ... ch=Jgbs188
#13 Re: Synchro mechanism
Have also checked out the website mentioned by Steve.
Eric, I got my shaft from a small web based jaguar part dealer here in Norway. ( sirwilliam.no ) They got most of their parts from sngbarrat ( I think ). It is run by a Jag enthusiast ( Tore ). They have some kind of deal with barrat. I could order from barrat myself, but then it will be at relatively high handling cost. Customs, postage etc. They order larger quantities at a time and can spread out the overhead cost.
However, the revers shaft is not from barrat, it came from their « network» Tore told me. And I didn’t ask any more. But if you order to US from this company in Norway I guess it would be very expensive.
Harald.
Harald.
