Are there any basic things I should verify on the IRS before I bring it out for a look and check?
#1 Are there any basic things I should verify on the IRS before I bring it out for a look and check?
Before I bought the car, my IRS had been completely rebuilt and installed. When fitted, the two rear wheels foul the inner arches fairly badly. The automobile is now equipped with 205/70 tires. Are there any basic things I should verify on the IRS before I bring it out for a look and check?
#2 Re: Are there any basic things I should verify on the IRS before I bring it out for a look and check?
What size wheels....probably just wheel/tyre combo causing wheels to rub....on the bump stops I assume or are these removed
#3 Re: Are there any basic things I should verify on the IRS before I bring it out for a look and check?
You don't say what car you have.
Randall Botha
'64 3.8 fhc & '51 Mk 7
