My heater motor was making some nasty noises and only working on hi-speed, so it suggested a bearing problem. When I removed the motor and opened it up, I found that one end of the shaft was located in a socket which was held in by a retaining ring with several legs. One of the legs had broken off, allowing for shaft movement. I've looked online everywhere to see if I can find any retaining rings / speed clips that would do the job. Does anyone know where I could find parts for the original heater motors? It seems a shame to discard it due to such a small part. I can swap in a different motor if necessary but I like to keep original parts where possible. Cheers.
Series 1 heater blower motor
#1 Series 1 heater blower motor
Lloyd
1968 Series 1.5 2+2 RHD (Aust. delivered)
"a work in progress after a 30y sleep"
1974 Series 3 roadster RHD (Aust. delivered)
"a work in progress after a 20y sleep"
#2 Re: Series 1 heater blower motor
These are called starkock washers. Take measurements and search your favourite online selling platform. You should find thousands.
#3 Re: Series 1 heater blower motor
Is that from a risque 1970's art house sci fi movie?
I think Chris meant starlock.
#4 Re: Series 1 heater blower motor
I think I did also. Typing in my phone before I'm fully awake........
