3.8 Engine Damper Alternatives
Topic author - Posts: 1295
#1 3.8 Engine Damper Alternatives
The 3.8l engine damper is like a dinner plate-almost the diameter of a 45 single.
The 4.2l damper has a much smaller diameter.
Anyone know if a 4.2l crank damper will fit a 3.8 engine? This is so I can attach a normal size trigger wheel.
Or will this mess up the harmonics?
James
James
Too many E types
XK120 SUs
Too many E types
XK120 SUs
#2 Re: 3.8 Engine Damper Alternatives
I believe a later XJ6 damper will fit. Later design.
Layne
Car #876005, 62 OTS
Car #876005, 62 OTS
#3 Re: 3.8 Engine Damper Alternatives
It'll fit OK. Can't answer the question about harmonics.
#4 Re: 3.8 Engine Damper Alternatives
The older it is, the harder and more brittle the rubber will have become, the less effective it will be …
#5 Re: 3.8 Engine Damper Alternatives
I would be very wary of substituting the later large mass damper for the earlier dinner plate type one. You do not want a fractured crankshaft
#6 Re: 3.8 Engine Damper Alternatives
I believe it to be a common substitute. Look at all the available High Performance balancers for these engines. None of them have a design like the early ones. Mass seems to be less or same with smaller diameter. Been running one for 25 years on my 3.8 installed by the Jag performance shop that built my engine.
Layne
Car #876005, 62 OTS
Car #876005, 62 OTS
#7 Re: 3.8 Engine Damper Alternatives
Thanks for the input.
I think I will try a 4.2 balancer and see what happens.
The rest of the rotating assembly is off to be balanced next week anyway, so I will add this into the mix.
It is amazing what a difference having it all balanced prior to assembly makes to the smoothness of it all.
Too many E types
XK120 SUs
Too many E types
XK120 SUs
#8 Re: 3.8 Engine Damper Alternatives
It’s possible to neatly shrink-fit a much bigger toothed wheel onto the back of the oft-supplied (by UK retailers) ProRace damper, which is actually Australian.
If you search in the Megajolt thread for rfs1957 you should find all the details from when I did it, I would send you the link but am fat-fingers-small-screen in an airport lounge so ………… not tonight.
Much, much neater and more elegant than fitting one on the crank nose.
#9 Re: 3.8 Engine Damper Alternatives
Thankyou Rory, I will have a look.
Too many E types
XK120 SUs
Too many E types
XK120 SUs
#10 Re: 3.8 Engine Damper Alternatives
Details are on Post #425 of the Megajolt thread.
#11 Re: 3.8 Engine Damper Alternatives
