#1 Timing chain tensioner
Posted: Sat Mar 30, 2024 2:20 pm
by Iansparky
Hi all
I am trying to slacken my upper timing chain, I have set engine to tdc, removed all 4 bolts holding the cams to the sprockets but when I try and turn the serrated plate clockwise on the adjuster it seems stuck, the pin depresses OK and the plate does move forward and backwards by a tiny bit but not enough to slacke the chain. I have loosened the 11/16 nut, do I need to remove this nut. Any ideas
Thanks ian
#2 Re: Timing chain tensioner
Posted: Sat Mar 30, 2024 4:33 pm
Why have you removed the bolts holding the cams to the sprockets...what are you trying to do... to adjust the upper chain you slacken the adjuster center nut...fully press in the locking pin.. look close the pin has serrations..press in till they dissengage..then you can turn the adjuster clockwise or anticlockwise....Steve
#3 Re: Timing chain tensioner
Posted: Sat Mar 30, 2024 5:18 pm
by Iansparky
I am removing the cams and the head, the plunger is definitely pushed in fully but the serrated plate will not turn I can only achieve a small. Rocking of the plate in both directions
#4 Re: Timing chain tensioner
Posted: Sat Mar 30, 2024 5:35 pm
Possibly the adjuster is seized...try giving it a few taps...even if you can't slacken the chain you may still be able to dismantle both sprockets on the camshafts...Steve
#5 Re: Timing chain tensioner
Posted: Sat Mar 30, 2024 5:37 pm
by Iansparky
OK thanks, will give it a try tomorrow
#6 Re: Timing chain tensioner
Posted: Sat Mar 30, 2024 7:00 pm
You can remove the nut/star washer and remove the serrated plate.. Steve
#7 Re: Timing chain tensioner
Posted: Sat Mar 30, 2024 9:58 pm
by tim wood
I’ve just refitted my head and had similar issues. Despite using the correct tool to depress the serrated plunger the plate wouldn’t turn. After a few attempts it freed off.
My guess it’s just a matter of keep trying
