Cam feed pipe washers
SimonBrown
#1 Cam feed pipe washers
Post by SimonBrown » Fri Apr 12, 2024 12:22 pm
Has anyone any experience with the uprated Goodridge cam feed pipe washers offered by SNGB?
They look significantly thicker than the original paper thin copper washers with the compression ring and
I am concerned about fitting them and finding the oil feed holes don’t line up properly.
Thank you
Simon Brown
1998 XK8 Coupe
2008 Mazda MX-5 2.0 Icon
1991 Mini Cooper 1.3i
Iansparky
#2 Re: Cam feed pipe washers
Post by Iansparky » Sun Apr 14, 2024 4:21 pm
HI Simon
You are welcome to borrow my goodridge washers and compare them to your banjos, they look OK on mine but I have thicker copper washers on already. I won't be needing mine for 2 weeks at least, so if they look OK then use them and order me some more.
Ian
1965 series 1 ots
1972 triumph spitfire
2016 Caddy van
SimonBrown
#3 Re: Cam feed pipe washers
Post by SimonBrown » Sun Apr 14, 2024 6:09 pm
Thanks Ian,
I’ll mail you
Simon Brown
1998 XK8 Coupe
