Voltage regulator problem??
JerryL770
#1 Voltage regulator problem??
Post by JerryL770 » Mon Apr 22, 2024 8:17 am
I hesitated to post this question yesterday because I know it is virtually impossible to advise from a distance.
Took my E out on the Stilton Run yesterday and had a couple of episodes where, as driving following traffic, the engine seemed to cut out and in. The tacho needle thrashed about, then power was restored and the car drove as normal. What could cause this?
Then I remembered as, dozing in bed this morning, that when I first went to start the car in the garage, in the morning, I turned on the ignition, waiting for the fuel pump to stop ticking, and everything went off/on a couple of times, accompanied by a relay clicking somewhere to my left. Nothing more happened and I had our trip out with the two occasions of cut out/in ??
I need to use the car today to go to my friends funeral. Any ideas? Ta.
Jerome Lunt
2008 MX-5 NC PRHT
Simonpfhc
#2 Re: Voltage regulator problem??
Post by Simonpfhc » Mon Apr 22, 2024 9:31 am
Obviously a bad connection somewhere, so firstly check all power connections around the battery. However, if the engine is also cutting out , you are losing ignition power. Could be the ignition switch failing, which is quite common. When it’s running, feel the key to see if it’s getting hot.
62 3.8 FHC
91 Porsche 928GT
JerryL770
#3 Re: Voltage regulator problem??
Post by JerryL770 » Mon Apr 22, 2024 9:38 am
Good point Simon. I will check that too.
Also, I suspect it may be the 4TR relay/voltage regulator(??) (I'm not as familiar with these electrics as it seems I need to be.)
Oliver from the Splined Hub will bring a spare to the funeral. Hope I don't conk out on the way.
Jerome Lunt
2008 MX-5 NC PRHT
JerryL770
#4 Re: Voltage regulator problem - sorted
Post by JerryL770 » Mon Apr 22, 2024 10:59 am
It's my ignition switch!
If I waggle the terminals on the back with the engine running, it's cutting out and in fast. Rat pie. Can't risk taking it out today. :cry:
Jerome Lunt
2008 MX-5 NC PRHT
Mich7920
#5 Re: Voltage regulator problem??
Post by Mich7920 » Tue Apr 23, 2024 4:11 pm
Hi Jerry,
Here is the solution
viewtopic.php?f=9&t=6885
Mich
Michel
#6 Re: Voltage regulator problem??
Post by DWW » Tue Apr 23, 2024 5:12 pm
Yes good mod, my key use to hat up especially in yhe hot summer. This completely so;ved that issue for me,
MarekH
#7 Re: Voltage regulator problem??
Post by MarekH » Tue Apr 23, 2024 6:02 pm
It's a little known fact.... that Danny is also the policeman from 'Allo 'Allo
:police:
#8 Re: Voltage regulator problem??
Post by DWW » Tue Apr 23, 2024 9:34 pm
I wos in a bet of a roosh when I tipped my reploy:bigrin: :bigrin:
