Subject: Old glue removal
MartinA
#1 Subject: Old glue removal
Post by MartinA » Fri Dec 09, 2011 8:20 pm
Just stripped the interior of my S2 OTS. Body looks good underneath the old carpets, but there is lots of old adhesive which needs removing, along with strands from the jute underfloor mats. Anyone have any suggestions on how to remove the old adhesive?
Dave K
Post by Dave K » Fri Dec 09, 2011 11:51 pm
Try thinners and a good sharp scraper. Evostick sell glue remover you can get it from B&Q or similar.
MarkE
Post by MarkE » Sat Dec 10, 2011 8:17 am
If you don't want to remove the paint as well, use kitchen roll soaked in petrol and left for 10 minutes. The adhesive softens up so you can then rub it off.
MartinA
#4
Post by MartinA » Sun Dec 11, 2011 8:10 am
Thanks - will try the petrol method as I assume the thinners will remove the paint also.
tonyabacus
#5 Re: Subject: Old glue removal
Post by tonyabacus » Sun Nov 24, 2019 2:52 pm
If you don't want the smell and fumes from petrol ordinary turps will do the job without removing the paint, just brush it on and leave for a few moments to soften and then use a plastic (not metal) scraper and kitchen roll.
#6 Re: Subject: Old glue removal
Post by Heuer » Sun Nov 24, 2019 3:08 pm
I use Halfords Tar remover - £4 for 500ml
S1 OTS OSB; S1 FHC ODB
Robsan
#7 Re: Subject: Old glue removal
Post by Robsan » Sun Nov 24, 2019 5:43 pm
Thanks - will try the petrol method as I assume the thinners will remove the paint also........
Thinners will not remove the original paint, or it didnt on my car. In my experiance and after removal of trim and carpets I soaked and soaked the surfaces with thinners then scraped and washed until original Jaguar surface was revealed. Also my car had been painted another colour with lots of overspray :-(
By using thinners I have washed away the crappy overpaint, revealing the original factory finnish. The bonnet is now original red on the underside and re- paint silver on the outside :wink: same as boot and boot lid
Just buy the cheapest thinners you can, my body shop man calls it gun thinners as they use for cleaning the spray guns
Mich7920
#8 Re: Subject: Old glue removal
Post by Mich7920 » Sun Nov 24, 2019 6:34 pm
Hi John,
I have what you need. I use it for old and new neoprene glue and also for the brushes.
All the glue of the seals disapeared after 15/20mn simply by brushing.
This Diluant is not very volatile as the other and it doesn't remove the old paint.
If you have any interest, Pm me.
Mich
Michel
1965 E Type FHC - On the road - 1963 E Type OTS - Angus Restoration
Gran Torino Sport 1975 - Renault 4cv 1956 - CItroen 15/6 1951 - CItroen Traction 1945
Citroen Coupé docteur 5Hp 1924 - Citroen B12 1926 - Torpedo Sygma 1913
Harley D. 1915 sidecar
#9 Re: Subject: Old glue removal
Post by mgcjag » Sun Nov 24, 2019 7:10 pm
Hi All.....do you realise that you are all replying to a thread thats 8 years old :bigrin:
Mich7920
#10 Re: Subject: Old glue removal
Post by Mich7920 » Sun Nov 24, 2019 7:26 pm
Perfect!
I'm younger new :bigrin:
Michel
mark10337
Switzerland
#11 Re: Subject: Old glue removal
Post by mark10337 » Sun Nov 24, 2019 7:46 pm
It can take a while to get it off.. he might have been struggling :bigrin:
-Mark
Mich7920
#12 Re: Subject: Old glue removal
Post by Mich7920 » Sun Nov 24, 2019 8:03 pm
how did this subject came back as "new" ???
Michel
#13 Re: Subject: Old glue removal
Post by mgcjag » Sun Nov 24, 2019 8:05 pm
Hi Mitch....any post you reply to pops up at the top of the list....Steve
