Shaking / vibrating engine
Quattrofrank
Norway
#21
Post by Quattrofrank » Mon Sep 22, 2014 5:07 pm
Finally my two post lift is up and running and I`m able to work on the car again.
I did change the spring, and the rubber on both sides for the spring. Havent been able to test it yet so I dont know if this did the trick or not.
One thing i did notice, on the pin that goen from the gearbox and through the spring and bracket there is a small hole. Is this for s split ring or something? Looks like I`m missing something, but I cant find anything missing if I look in the part list.
Anyone know?
Post by christopher storey » Mon Sep 22, 2014 5:39 pm
The hole in the pin isfor a split pin to be used to lock the gearbox against excessive up and down movement during transport of the car when new, ( particularly by sea ) . When the car is ready to be commissioned, the pin is removed, allowing the gearbox to float on the spring. So yours is correct
Quattrofrank
Norway
#23
Post by Quattrofrank » Tue Sep 23, 2014 7:23 am
Thank you.. :)
Looks like everything is in place then.
Hopefully I will be able to test it soon, just need to install the new exhaust and fix the handbrake.
Quattrofrank
Norway
#24
Post by Quattrofrank » Tue May 12, 2015 9:08 pm
Thought I should give an update
Did some testing afterwards and it didnt really go away.
Today I removed the gearbox tunnel cover in order to remove the propshaft when I realized two things:
1: It looks like someone forgot to tighten the propshaft bolt, found them loose allowing the propshaft to move slightly relative to the output flange on the gearbox
2: The UJ was really bad with a lot of play
I think those two things combined might be what I was feeling and hopefully it will be good now. Of course I`m changing everything besides the gearbox it self so it is not easy to know what was the cause if the problem is now gone.
Paul Buckley
#25 Re: Shaking / vibrating engine
Post by Paul Buckley » Tue Oct 01, 2019 5:32 pm
Did replacing the u/j solve the vibration?
Or did you find something else?
