My clutch slave cylinder was leaking and I discovered there was a little rust inside. I chemically dipped the cylinder to remove the rust and now I am honing the cylinder to get a smooth surface. But how much can I hone before it will start to leak?
I did not measure the diameter before I started honing, but now the diameter is 22,3mm. The new rubber seal is 22,0mm on the piston side and the lip on the sealing side is 23,6mm.
Does anyone knows?
Jon
How much can I hone my clutch slave cylinder?
#2 Re: How much can I hone my clutch slave cylinder?
Jon -
I would expect that the seal could take up a substantial increase in bore size, probably more than you have the patience to reach with a hone.
I doubt anyone can give an absolute answer as it will depend mostly on the dimensions and flexibility of the replacement seal which will vary wildly with manufacturer.
Personally, if the pitting was deep enough to make me ask the question I'd change the cylinder or sleeve it just because it's pain to remove later if it does weep !
Joe
Joe
1963 3.8 OTS
How long is a piece of string ?
There's no answer.
I would keep going, having regularly "saved" slaves (both clutch and brake-calipers) that had marked bores ; my experience suggests you can get away with murder and they work just fine. And when they don't, it's a weep not a collapse.
There's no answer.
Hi , Look you have it off , you wiil have to bleed the system, it may or my not weep again ???? , for the price of a new one I dont think its worth the hassle / gamble , keep the old one for tours etc as a get you out of poo moment ? just my 2 euros worth
Its a way of life not a hobby
Darren . 64 4.2 modded 69 4.2
