LHD TO RHD Conversion - Pedal Boxes
Topic author - Posts: 18
#1 LHD TO RHD Conversion - Pedal Boxes
I am in the process of converting a lhd 1962 roadster to rhd, I have hit a problem; can someone tell me the easy way of removing the clutch / brake pedal box / brake booster from the bulkhead without completely dismantling it?
Hi unless you have already found out the pedal pads unbolt and you skew the box to get it out .
hope this helps Barrie
