cooling and waterpump pulley misalignment problems
64etype
Post by 64etype » Fri Feb 26, 2016 3:28 pm
lataud wrote:.... but i remembered that the mechanic had to change the order of the plugs in relation with the "123 electronic " manual , when he fired the engine for the first time. actually the engine starts very well and runs without any problem. (except over heating of course !)
I'm not at all familiar with the 123 system, but this sounds like he changed the firing order??? I do know that the engine will run surprisingly well albeit with a very slight miss with two wires crossed. Again, I'm not familiar with the 123, but this seems strange.
Eric
neal herridge
Post by neal herridge » Fri Feb 26, 2016 5:27 pm
David are they saying it will work with the 4.2 engine as well even though the slot is closer to the front. Also what temp does it work at my non correct stat is 74o which may compensate for it not covering the bypass.
Thanks Neal.
Post by Heuer » Fri Feb 26, 2016 6:22 pm
Temp of stat is 74C although there is a 'winter' 82C version. With the thermostat mounted in the elbow the sleeve protrudes 10mm into the manifold so the by-pass slot needs to be deeper than that otherwise the sleeve will cover it when cold. Providing your slot is deeper than 10mm it will work. You could make the elbow recess deeper of course to make sure the sleeve is clear of the slot. Suggest you invest in a LR thermostat (around ?3) and work out if it will operate correctly in the 4.2 and report back.
S1 OTS OSB; S1 FHC ODB
neal herridge
Post by neal herridge » Sat Feb 27, 2016 5:25 pm
I will get one David & report back , if I make the recess deeper may need a clamp ring to trap the stat worth the ?3/?4 to try.
Thanks Neal.
Post by Heuer » Sat Feb 27, 2016 6:33 pm
Well done Neal. Let me know if you need any information or help.
Polse7317
Post by Polse7317 » Sat Feb 27, 2016 7:09 pm
I am checking the order of the plugs on the "123 ignition " , trying to understand what has the mechanic changed in the plugs order :
he has rotated all the plugs without changing the sequence of180?:
Here is the order i found:
at the beginning it was A and now B :
Y tried the A position .....it was not a good idea , not fine !
Post by mgcjag » Sat Feb 27, 2016 7:38 pm
Hi Yves...what you need to check is where does the rotor arm point to when No1 piston is on its compression stroke.......where it points you then label as 1 then just carry on around with the same number sequence as you have.........did you have this engine rebuilt?
Polse7317
Post by Polse7317 » Sat Feb 27, 2016 8:20 pm
Yes it has been rebuilt .
I'll do what you say with a help of a friend who is better mechanic than me, he told me exactly what you say today....!
ralphr1780
Post by ralphr1780 » Sat Feb 27, 2016 9:32 pm
Yves,
The configuration B is the one which should be correct, BUT on condition that distributor is correctly placed and not rotated 180 degrees.
When you place the timing pointer at the front damper makings at 0?, the rotor arm should point to cylinder 6.
Please check that and revert with your findings.
Ralph
'69 OTS + '62 OTS - Belgium
neal herridge
Post by neal herridge » Sun Mar 06, 2016 4:47 pm
I have posted an update re the stat problems under the thermostat thread.
Neal.
marc
#131 Re: cooling and waterpump pulley misalignment problems
Post by marc » Mon Aug 21, 2017 9:09 am
Hi Yves,
sorry for speaking again about that subject, i recently got the same situation as you: may i ask you what was the cause of your initial overheating problem, when you first fired the engine after complete rebuild?
Thank you!
Marc (3.8 FHC, late 1963)
Marc 1963 3.8 FHC
