brake calipers with 2,88 differential from XJ-S
carlv12
Spain
#1 brake calipers with 2,88 differential from XJ-S
Post by carlv12 » Thu Mar 24, 2016 7:55 pm
Hello,
there are different stories about upgrading an E-Type V12 with a 2,88 differential from XJ-S:
1) must I use the XJ-S brake calipers instead of the E-Type ones?
2) must I use the XJ-S hand brake brake calipers instead of the E-Type ones?
I hope here on this Forum there are a few experts that already have done this conversi?n and know bout this question.
Thank you in advance and best regards from Valencia (Spain)
Carlos
Zei220
Post by Zei220 » Thu Mar 24, 2016 9:21 pm
I changed the diff on my s2 from the 3.54 to the xjs 2.88 and reused the original brake calipers and handbrake, without problems.
S2 4.2 FHC
S1000xr sport se
"You only live once, but if you do it right, once is enough..."
D COUPE
#3 2.88 DIFF
Post by D COUPE » Sat Mar 26, 2016 2:16 pm
I did the 2.88 diff swap and used all my original brakes .....
DC
ITS NOT WHAT YOU DRIVE ITS HOW GOOD YOU LOOK IN IT
