Hi guys,
I have these two carpets in my 2+2 set.
What are they for ? I thought "under- dash", but I could not find any orientation nor place for them.
Where should I put them ?
Carsten
What are these carpets for ?
#1 What are these carpets for ?
Jag E '66 S1 2+2, 74’Citroen DS 23 Pallas iE, 73’ Citroen SM 3.0, 75’ Concept Centaur MK1, 54’ Citroen 11 BL, 71‘ Velosolex, 88‘ Unimog U1650
#2 Re: What are these carpets for ?
Hi Carsten.....it shows very similar looking shapes as underdash panels but for an ots on the Skinner site http://www.john-skinner.co.uk/jaguar/e- ... 2ltr/#trim
#3 Re: What are these carpets for ?
Ok. Hm.
I bought them a few years ago from Aldridge- I'll ask them.
Carsten
Carsten
#4 Re: What are these carpets for ?
Hi Carsten.....looks like parts 601 on the Aldridge site....look at the small picture by the list of parts http://www.aldridge.co.uk/services/schematic.cfm?id=3 cant seem to get the link to work but if you look at the Aldridge Site under S12+2 4.2 in the trim section ...other ......it shows exactly what you have as under dash panels should be 3 parts http://www.aldridge.co.uk/PartsImages/J ... lus2ud.jpg
#5 Re: What are these carpets for ?
Hi Carsten,
They are the under dash hardura panels as Steve mentions and you should have some similar shaped jute pieces. Although it's a different model here's some pictures of mine (Interior trimming).
I did find that these panels needed to be fitted before the carpets which butt up against them. Also, if your car has one (I'm assuming it would), you'll need to fit the vinyl covered wiring loom conduit panel beforehand.
Chris
Chris
#6 Re: What are these carpets for ?
Carsten,
I recognise the shape of the left one as being the piece that goes from the brake pedal arm and upwards (rearwards) to the steering column, the right one I'm not quite sure about, but it's quite similar in size to the piece on the passenger side that goes from the firewall and upwards (rearwards) to the parcel shelf, mine had a small cutout to clear the adjustable nozzle of the air vent control blades and the control wire. Mine were original to my car, 50 years old, so if you need I can take some pics from my car and send to you.
rgds
rgds
David
S2 OTS '70 (arriving)
#7 Re: What are these carpets for ?
Hi guys,
Now isn't that wonderful - I got in contact to Simon Aldridge himself, and he offered to send me a fitting set for free- even paying freight !
I cannot praise them high enough- the parts fitted nicely, always an open ear when I had to ask, and I got a free replacement years after buying.
Wonderful company. Highly recommended.
Carsten
Carsten
