Carsten,Durango2k wrote:It can be seen here:
http://www.sngbarratt.com/ProductDetail ... 98e3e8&l=7
It looks like it is kept on its axle using 1 mm split spins or similar.
My bet is I will be taking them apart by tomorrow and find out what went wrong. I think either the split pin sheared or (worse) it has worked its way into the softer alloy. That would be tricky to repair then, if not impossible.
But at over 180 Euros each, ouch, that is expensive, I will find a way.
Carsten
They are fixed with pins, but I've never seen one sheared, or a broken lever.
Take off the bells & pistons. Check that all 3 jets lower by about 1/8" when you pull the choke, and that the jets return to the original height when you release the choke. If they do then your choke rings, levers, and jet return springs (beneath the diaphragms) are working fine.
The other part of the choke mechanism cracks the butterfly a bit, via the cam rods. See the bits marked in yellow here:
