Rear camber setting tool
Topic author - Posts: 1074
#1 Rear camber setting tool
Hi anyone know where I can get a rear camber setting tool . Not the gauge itself. But the tool that sets the road height while ,eye one end hook the other , while you check the camber ?? Cheers for any ideas
Its a way of life not a hobby
Darren . 64 4.2 modded 69 4.2
#2 Re: Rear camber seeing tool
I use a turnbuckle from the building center.
#3 Re: Rear camber seeing tool
If your irs is not ye fitted set it up off the car.....much easier with it on the bench..then just bend up some steel rod to fit....dimensinos in the manual
#4 Re: Rear camber setting tool
Just level the wishbones / drivshafts and adjust based on what ride hight you think you be running.
#5 Re: Rear camber setting tool
Hi Frank . Yes , been thinking and my settings will be a lot different to standard ones . So yes will set up when built and settled . Probably use Northampton motorsport for exact setting up and corner weighting . Cheers. Darren
