FACTORY FIT - Series 1 3.8
#261 Re: FACTORY FIT - Series 1 3.8
Post by Heuer » Fri Aug 23, 2019 3:03 pm
I have rolled the earlier post by Geoff Green, details observed by Ian Howe and some of my own research into a single post. Let me know if anyone has more information or edits are required.
Brake Fluid Filler Caps
Filler Cap and Level Indicator for Brake Fluid Reservoir were made by two manufacturers - Sovy Ltd and Lockheed.
Lockheed
These were large black caps marked 'NIVOCODE', 'Lockheed' and some French descriptive text; the spade terminals were vertical. These were used on the first group of cars approximating the outside bonnet lock production with the highest car found so far 875190. The level sensor consists of a float inside a round aluminium cover and were also used on the Jaguar Mk 1 and 2 saloons. Unlike the Sovy caps the wires should be removed before the cap was unscrewed. Many owners did not bother which is why the wires are twisted on most cars but they should not be.
'Nivo' is French for level, 'code' is French for rule, so 'level rule'; Nivocode is not a registered trade name, merely a product range of fluid level sensors. They also made matching brake bottles in glass, 'Nivoclair' ('clair' = clear), which regrettably Jaguar decided not to use :banghead:
The August 1961 SPC illustrates the Nivocode sensors - C18197 'Filler Cap and Level Indicator':
E/122/1 Owners Handbook (note wires are not twisted):
Note the corrosion caused by water in the brake fluid:
Plastic float:
9600 HP with Nivocode sensors March 1961:
SOVY (U.K.) Ltd 54 Park Lane. Croydon, Surrey
From sometime in August 1961 a revised Sovy design consisting of a multi piece cap with the top of black plastic having horizontal terminals and an attached aluminium screw cap was introduced for production. The design allowed the cap to be unscrewed from the bottle without the need to disconnect the wires. The Patent for the Sovy 'Liquid Level Indicator' was filed on 24th October 1959, revised on 9th May 1961 by Eric Bernard Aird Marsh and granted on 10th April 1963. SOVY (U.K.) Ltd continued to supply Jaguar through the Series 3 E Type and supplied other automotive manufacturers like Aston Martin, Rover, etc. SNG Barratt purchased SOVY U.K. in 1990 and continues to build the filler cap and level indicator.
The early pre-production cars were fitted with a Sovy black cap sensor which had no identification markings as they were themselves prototypes. They were constructed differently to the later sensors and quite crude:
Jaguar (Belgium) photo of 77 RW during the demonstration runs at Geneva March 1961 using black Sovy unmarked caps:
9600 HP during very early testing with unmarked Sovy sensors:
More than one very early production car (e.g. 875039) have been observed with the Sovy unmarked caps and left the Factory with them fitted. As these early sensors were pre-production they could not have been in-service replacements.
From sometime in August 1961 the Factory stopped using Lockheed NIVOCODE and started fitting Sovy sensors of a modified design. These had black caps with 'Sovy' and 'Made in England' markings as seen on on 860058 built in November 1961:
Another November 1961 car:
This style of sensor continued to be fitted until July 1962 when the square bottles were introduced.
NIVOCODE and Sovy sensor comparison:
The black cap changed to a white cap when the bottles were changed from round to square in July 1962.
The black caps are still produced with the Patent numbers added:
In March 1963 a new style of sensor was introduced in an attempt to avoid water ingress. These had a push fit sealing knob (easily lost!):
The new waterproof caps. Note Patent Pending imprint but the patent number does not exist:
In October 1963 a Service Bulletin was issued with advice on an in-service modification:
In January 1964 protective rubber caps were introduced in a further attempt to waterproof the sensors
Dispersed throughout all series of production red coloured caps have been observed. These are original Sovy and frequently used on Lotus's however as many sensors were replaced in service (the aluminium parts corroded due to water in the brake fluid) it is difficult to know whether they were Factory fitted. All the red caps I have seen have the Patent number so, if Factory fitted, mid 1962 until March 1963 when the waterproofed versions with the push on cap were used. My guess is the red caps were in service replacements rather than Factory fit given their spread over all Series cars.
Factory Fit timeline (for concours):
Prototype and pre-production cars - either Sovy unmarked black cap or Lockheed NIVOCODE
First ~500 cars up to August 1961 - Lockheed NIVOCODE sensors as illustrated in the August 1961 J.30 SPC
August 1961 to July 1962 - black cap Sovy sensors with 'Sovy and 'Made in England' imprint
July 1962 to March 1963 - white cap Sovy sensors with 'Sovy and 'Made in England' and maybe 'Patent applied for' imprint
April 1963 onwards - white cap Sovy sensors with Patent numbers and push fit waterproof caps
January 1964 onwards - protective rubber caps, which could be retrofitted to earlier cars.
Trivia: A report by Norman Dewis on the Geneva show demo cars had this to say: "Brake fluid leaking from reservoir bottles, suggest close inspection of fluid bottles for leaks".
The Patent: Once a Patent is filed (in the case of Sovy - 9 May 1961) the owner can use the words 'Patent Pending' or 'Patent applied for'; this phrasing is converted to the Patent Number once it is issued (in the case of Sovy - 10 April 1963). So any cap produced with the Patent numbers should have been after April 1963 yet they seem to have been made some 10 months earlier! The waterproof cap of March 1963 have 'Patent Pending' on them but the quoted Patent number does not exist; either it was withdrawn or the application was never filed. They seem to have been playing free and loose with the letter of Patent law. :shrug:
S1 OTS OSB; S1 FHC ODB
MarekH
#262 Re: FACTORY FIT - Series 1 3.8
Post by MarekH » Fri Aug 23, 2019 3:30 pm
Is it even representative to include a factory demonstrator in this section? The car being quoted clearly had different reservoir caps at different times, a different engine by the sounds of it, different side steering wheel and heavens knows how many other changes in specification, so it hardly helps nail down what was fitted by the factory to production cars. If anything, it somewhat muddies the waters in this respect.
Surely the point of this thread is to look at cars that haven't been altered?
#263 Re: FACTORY FIT - Series 1 3.8
Post by Heuer » Fri Aug 23, 2019 4:12 pm
Yes, it is a 'Factory Fit' thread and it appears Jaguar were testing the Sovy prototype sensors which were, for obvious reasons, unmarked. The design was changed based on the feedback but in the meantime NOVICODE sensors were fitted to both the E-Type and Mk2. However a few very original early cars (two digit VIN) have been observed with the unmarked caps fitted from the Factory. As the caps were never released in the wild they cannot be after-market and all evidence points to them being original fit.
These are observations and the only hard facts we have are the drawings of the NOVICODE sensors in the J.30 SPC and the Owners Handbook. So from a documented originality point of view (e.g. concours) we must say all the cars up to around August 1961 should have had the NOVICODE sensors.
I included the development history to avoid having to explain to owners who say "but my car is different"!
Ian Howe
#264 Re: FACTORY FIT - Series 1 3.8
Post by Ian Howe » Fri Aug 23, 2019 8:43 pm
Hi David
Thanks for the summation and balanced views.
Ian
Ian Howe
#265 Re: FACTORY FIT - Series 1 3.8
Post by Ian Howe » Wed Oct 30, 2019 8:11 am
Boot Boards aka 'Cover Assemblies'
The early (no idea for how long) Cover Assembly over the Petrol Tank did not have the rubber buffers (BD4321 x 3) in the support strip as found on later cars.
Early floorboard assembly showing original support strip and later painted strip:
Detail of the two support strips, early strip still attached to floorboard:
The strips were part of the 'cover assembly' and do not have a part number. The cover assembly was held in place using Parker- Kalon screws and special washers (see post #152).
Ian
#266 Re: FACTORY FIT - Series 1 3.8
Post by Heuer » Mon Dec 09, 2019 3:58 pm
Exhaust System
The 3.8 exhaust system was changed several times during production to make in service fitting easier and to reduce noise. The whole system was mild steel painted semi matt black as a rust preventative as can be seen in this early photo taken at the Factory. The mufflers were chrome plated. Jaguar records show the down pipes and silencers cost them £2.15.6d whilst the tail pipes and mufflers cost £4.2.0d.
Later in production the silencers alone were given an aluminised finish.
Before continuing it is worth defining the various parts of the system, using Jaguar terminology:
A. Front and rear down pipe assemblies from manifold to silencer
B. Clip, securing down pipes to silencers x2
C. Twin Silencer assembly (these would be called ‘mufflers’ in the USA)
D. Rubber mounting for suspension of silencers to body x4
E. Clip securing tail pipes to silencers x2
F. Exhaust tail pipe assembly
G. Rubber mounting for suspension of tail pipes to body; Bracket for fixing of rubber mounting to boot
H. Left and right Muffler assemblies (these would be called ‘resonators’ in the USA)
The silencers, tail pipes and mufflers came as separate items with some spot welding required:
The first changes to the system were introduced in November 1961 (850179/860012/875608/885059) when the method of joining the tail pipes and mounting the mufflers to the body was revised. The new parts could be retrofitted to earlier cars provided all listed parts were used.
NOS tail pipes showing original black heat resistant paint:
In October 1963 (850755/861271/879990/889096) a new twin silencer was introduced which was baffled, whereas the earlier silencers were straight through. These reduced noise. To compensate the mufflers were revised with less effective sound absorption. The new silencers could be retro-fitted to earlier cars provided the rubber mountings were also updated along with the other parts listed. Jaguar stated the new mufflers should only be paired with the new silencers and not used with the earlier version.
In August 1964 (850897/861697/881635/890664) the twin silencer assembly was given an aluminised steel casing. All other pipes and fittings were painted matt black.
Notes:
1. There is an apocryphal tale the front down pipe was painted black and the rear down pipe painted silver to make recognition/fitting easier at the Factory. There is no evidence to support this story and I can't think Mr Arthur Whittaker, Jaguar's Chief Buyer, would have countenanced such a cost when a crayon mark would suffice! The whole mild steel system was painted heat resistant semi matt black which was standard industry practice at the time. The silencers were eventually given extra rust protection with aluminised steel casing.
2. The early silencers were a straight through design as were the mufflers. The silencers were changed to a baffle design after noise 'boom' complaints from customers. The mufflers were then modified with less effective sound absorption to maintain the sporty sound but produced at the rear of the car rather than under the passenger compartment.
3. Aluminised steel used for the later silencers is steel that has been hot-dip coated on both sides with aluminium-silicon alloy producing a material with a unique combination of properties possessed neither by steel nor by aluminium alone. Aluminised steel is more resistant to corrosion.
3. I can find no record of which company manufactured the exhaust system for Jaguar. CE LAST (Silencers) Bolton Ltd were a major manufacturer at the time as were Servais Silencers of Cricklewood and Northampton who specialised in straight through systems and supplied Aston Martin.
My guess is Servais supplied them as they specialised in straight through silencers and auxiliary silencers (the E-Type mufflers).
richard btype
#267 Re: FACTORY FIT - Series 1 3.8
Post by richard btype » Mon Dec 09, 2019 9:25 pm
I wonder whether Mr Arthur Whittaker could have possibly realised how he would receive such infamy?!
Do any images of him survive I wonder...
Chassis no: 860403
DOM - 11th April 1962
#268 Re: FACTORY FIT - Series 1 3.8
Post by Heuer » Tue Dec 10, 2019 10:50 am
Arthur 'Ticker' Whittaker biography here: https://www.jaguarheritage.com/jaguar-h ... whittaker/
Tom W
#269 Re: FACTORY FIT - Series 1 3.8
Post by Tom W » Wed Dec 11, 2019 5:38 pm
Jaguar Classic produced their exhaust from original drawings. That system has one silver and one black down pipe, so one can assume there is some original evidence to support this.
https://parts.jaguarlandroverclassic.co ... introduced
Interestingly, on your photo of the underside of the car in production, the lower wishbones look to be black, rather than cad plated. What do we know about this?
Tom
1970 S2 FHC
bopperd
#270 Re: FACTORY FIT - Series 1 3.8
Post by bopperd » Wed Dec 11, 2019 6:12 pm
Ian Trapp and I discussed this when he was here looking at my car. He said that while there appeared to be no documentation of the change from black to cad, speculation was that it was only the first hundred or so cars that had black wishbones.
Dave Schinbeckler
'61 E-type OTS
'05 X-type Estate
'88 Ferrari Testarossa
'82 Dodge W-150
poofacio
#271 Re: FACTORY FIT - Series 1 3.8
Post by poofacio » Wed Dec 11, 2019 11:15 pm
I've owned 5 of the first 91 RHD cars, they all had black wishbones if that helps!
61 RHD OBL DHC
61 flat floor DHC
61 FHC
63 FHC
66 FHC (QUAD LIGHTS)
ysmalkie
Poland
#272 Re: FACTORY FIT - Series 1 3.8
Post by ysmalkie » Wed Dec 11, 2019 11:30 pm
Looking at the photo, also the wheel arch mudshield panels are body colour?
Tadek
Tadek
Jaguar XK120 OTS
Austin-Healey 100 BN2
peters3103
#273 Re: FACTORY FIT - Series 1 3.8
Post by peters3103 » Thu Dec 12, 2019 6:25 am
I note the Jaguar Classic tail pipe assembly is in silver rather than black as originally specified.
61 FHC
99 XKR FHC
#274 Re: FACTORY FIT - Series 1 3.8
Post by Heuer » Thu Dec 12, 2019 11:20 am
The Jaguar Classic exhaust has aluminised pipes and silencers so whilst practical, not to original period specification and the copy appears to be based on the October 1961 version.
We cannot hold it up as a sterling example of originality! Unless someone can come up with supporting documentation we must go with the Factory production line photo which shows the system as being black. My other reasoning is:
1. The SPC drawings (the draughtsmen drew what they saw) do not illustrate a coded difference in the down pipes
2. There is no mention of a down pipe 'polarity' marking in the Spare Parts Catalogue, Spare Parts Bulletins, Service Bulletins, Service Manual or Owners Manual
3. No other handed parts on the car were so overtly marked
4. It would serve no purpose at the Factory as the fitters were experienced
5. The unacceptable added cost of production when the bought-in price for down pipes and silencers was £2.15.6d - a sticker or the ubiquitous yellow crayon mark would have sufficed
6. It would have caused confusion at Service Centres and with customers - "Why don't my down pipes match? It looks terrible"!
7. Books devoted to originality by Thomas Haddock, Mike Mueller. Anders Clausager and Philip Porter make no mention of the coded down pipes
8. That photo says it all
Yes, the early cars had black painted suspension components. We do not know the date when this changed to Cadmium plating.
I think it is a black car.
ysmalkie
Poland
#275 Re: FACTORY FIT - Series 1 3.8
Post by ysmalkie » Tue Jan 14, 2020 3:50 pm
So, I decided to help out a bit and write a piece on the back glass (glass in boot lid). David, please feel free to edit as you wish.
Chronologically:
1. Start of e-type production:
BD19362 GLASS IN BOOT LID, clear
2. April/May '62, accodring to SPB P.56:
"Electrically heated backlight, which prevent misting or frosting of' the glass are available from Jaguar Spares Division when specially ordered:"
BD21942 BACKLIGHT(CLEAR GLASS)
BD22742 BACKLIGHT("SUNDYM"GLASS)
3. June '62, according to SPB P.60, starting from chassis 860479 and subs. & 886014 and subs.:
"'E1 type Fixed Head Coupe models bearing the above and subsequent chassis numbers incorporate numerous modified Body Panels. The use of the new Panel necessitate alterations to various Trim Panels and Casings."
This meant that since the boot lid was modified, the glass had to be modified, too, and the following new glass versions were to be used
BD19650 GLASS IN BOOT LID
BD22740 GLASS IN BOOT LID (CLEAR GLASS), heated
BD22744 GLASS IN BOOT LID ("SUNDYM" GLASS), heated
The glass changed dimensionally as follows:
NOTE - TOP and BOTTOM is reversed.
I checked my glass from '63 and the A=815mm, so somewhere in the middle..
It would be interesting to get some real measurements from early glass.
LOGOS
The SUNDYM glass had a special logo. Here is a sample from '62 S1 Chassis 888330 manufactured March 1963.
Logo dated from Q4 '62:
Although the logo is from Q4, I do not think it was different in Q2.
Starting from '63, logo changed to have TRIPLEX printed in a thicker font:
Tadek
Tadek
Jaguar XK120 OTS
Tony
#276 Re: FACTORY FIT - Series 1 3.8
Post by Tony » Wed Jan 15, 2020 12:38 am
In the picture of the underside of the e-type above. What is the radiator looking object just in front of the rear suspension cage. I cannot make it out from the picture. The exhaust seem to run through it.???? :scratchheadyellow: :scratchheadyellow:
Tony
Tony (E typed)
Tony
MarkRado
Austria
#277 Re: FACTORY FIT - Series 1 3.8
Post by MarkRado » Wed Jan 15, 2020 4:55 am
Seems to be the next car in the line
1963 OTS 880436
Tony
#278 Re: FACTORY FIT - Series 1 3.8
Post by Tony » Thu Jan 16, 2020 12:10 am
That makes sense. You are right. Well spotted.
Tony (E typed)
Tony
peters3103
#279 Re: FACTORY FIT - Series 1 3.8
Post by peters3103 » Thu Jan 16, 2020 1:23 am
An optical illusion, it does look like the exhaust pipes run through the radiator.
61 FHC
99 XKR FHC
Ian Howe
#280 Re: FACTORY FIT - Series 1 3.8
Post by Ian Howe » Wed Feb 19, 2020 1:55 pm
HEAD LIGHTS
Several of the books on E Type originality mention that early cars were fitted with Lucas PL700 or other types - and some cars were fitted with non-PL lights. Whilst I guess this type of light could have been fitted after production - I would seem sensible to fit a more modern sealed beam unit - indeed this car had a later GE sealed beam unit on one side. The other light seems original as shown below?
The tripod version of the BPF (British Pre-Focus) light unit was fitted to many cars from 1945 to 1963 - and was fitted to 875039.
Light Bulb and Lucas adaptor. To use BPF lamps on a non-BPF headlight loom (as fitted to the E Type) an adaptor was fitted - Lucas part number 554691
Bulb Detail
Ian
