Under dash panels
Post by Heuer » Tue Dec 09, 2014 11:59 am
Yes you can mirror image for LHD or just cover the opposite side with vinyl if using aluminium version.
S1 OTS OSB; S1 FHC ODB
david muir
#22 Re: Under dash panels
Post by david muir » Sat Jun 17, 2017 12:59 pm
David, Found this older post with the template links you kindly provided a couple of years ago. However the links ,through Dropbox ,are no longer available. Can you provide the again please?
1964 3.8 FHC
#23 Re: Under dash panels
Post by Heuer » Sun Jun 18, 2017 1:59 pm
Oops - forgot to update those links when Dropbox moved. Fixed!
These work for the S2 from the Knowledge Base:
S2 Under dash templates: Click for PDF of Card 1 Click for PDF of Card 2 Click for PDF of Card 3
These are the S1 dash panels:
https://www.dropbox.com/s/ubk7e4s1h8vj8 ... n.pdf?dl=1
https://www.dropbox.com/s/p48pfdrumjczp ... n.pdf?dl=1
david muir
#24 Re: Under dash panels
Post by david muir » Sun Jun 18, 2017 5:11 pm
Thanks David!
D
1964 3.8 FHC
