Kenlowe fan and dynamo?
#1 Kenlowe fan and dynamo?
Hello people.
According to Jonathan Wood the original electric (lawnmower) fan on the 3.8 drew between 6 and 7 amps. It was notoriously feeble. My recent acquisition is currently undergoing various surgical sequences before she gets taken into my custody. One of the things that had already been done to her was the fitting of a Kenlowe fan (a very standard upgrade on the 3.8s). The original fan is still in situ, but has been disabled so that only the Kenlowe engages, otherwise too much power would be drawn by both fans. I don't know how much the Kenlowe draws. I have heard that the poor little dynamo (another cute foible of the 3.8 that went out with the introduction of the 4.2 with its alternator), slightly dodgy at the best of times, struggles with the Kenlowe.
Should I be worried? Or simply learn to juggle the fan and the charging in traffic? (I'll have my hands full enough double clutching the Mossbox...). I would hate to be compelled to modify the cute foible and replace the dynamo with an alternator. But I would also hate running flat every so often in traffic. I suppose this is another reason why I would probably have to live with the poor lighting the headlamps will achieve at night, as powering them up would suck even more amps and exhaust the dynamo.
Any wisdom much appreciated.
Frank
1963 3.8 FHC
1963 3.8 FHC
#2 Re: Kenlowe fan and dynamo?
The fan runs when the engine is hot and probably idling in a queue. At idle the old dynamo generates very little juice so any electrical items on will be running off the battery. Assume a 50 amp hour battery and ten amps from your fan...five hours before it is flat. It would be less in a real queue as the fuel pump uses about 2 amps and your spark will be using an amp or so. But so long as your battery is good and it's not dark with the lights on too you should still be good for well over an hour idling before the battery fails. My 3.8 is on the dynamo and non issues so far...I would not be unduly worried unless you are going somewhere busy and hot.
#3 Re: Kenlowe fan and dynamo?
Been running with a dynamo and a Kenlowe for over 10 years, including Hot and Busy, and never had the slightest issue.
And have a lower-capacity battery.
viewtopic.php?f=3&t=4426&p=78154&hilit=battery#p78154
And have illegal higher-wattage H4 bulbs (yes, with relays).
viewtopic.php?f=3&t=5214&p=36869&hilit=regulator#p36869
And have the original regulator.
viewtopic.php?f=3&t=4428&p=30423&hilit=regulator#p30423
It's not a problem.
It's not a problem.
#4 Re: Kenlowe fan and dynamo?
Rory says it all....not a problem. Incidentally Coolkat in the USA sell a drop in replacement for the old and useless flymo fan. Fits straight onto the existing fan mount and works a dream...and looks close to factory too...
#5 Re: Kenlowe fan and dynamo?
Thanks guys
That's reassuring.
I may even see if I could get a halogen option for the lights
That's reassuring.
Frank
1963 3.8 FHC
1963 3.8 FHC
#6 Re: Kenlowe fan and dynamo?
The Coolcat fan is the best aftermarket unit I've seen to date. It integrates beautifully with the factory fan shroud, so that you get a good pressure drop behind the radiator for efficient cooling. I ran on on my '66 FHC and had no problems with overheating in Southern California traffic. As I recall, the current draw was around eight amps, so your dynamo should be able to cope if you're not running a bunch of other accessories at the same time.cactusman wrote:Rory says it all....not a problem. Incidentally Coolkat in the USA sell a drop in replacement for the old and useless flymo fan. Fits straight onto the existing fan mount and works a dream...and looks close to factory too...
Mark (Moe) Shipley
Former owner '66FHC, #1E32208
Former owner '65FHC, #1E30036
#7 Re: Kenlowe fan and dynamo?
+1 on the Coolcat system and most anything made by Mike Frank. My experience with mine is identical to Moeregaard's. According to Mike, his motor for the series I's draws less than 7 amps which is pretty amazing for the amount of air that it moves.
#8 Re: Kenlowe fan and dynamo?
Great, if the Kenlowe does not work too well, I'll get a Coolcat. I think the Coolcat is a US product, and the Kenlowes are more easily obtainable here, but presumably SNG Barratt also supply the Coolcats.
But first, I need the CAR! Lots happening to her as we speak. Looks like the garage construction will beat the car finalisation at this rate!
This forum is a wonderful font of info. I will feel less alone and palely loitering when faced with all the inevitable foibles in the months and years ahead. Especially as I ain't no mechanic's derriere.
Frank
1963 3.8 FHC
1963 3.8 FHC
#9 Re: Kenlowe fan and dynamo?
Ken Verity in Rotherham sells the Coolcat fan. Fosseway sell something very similar but include a matching cowl: http://www.fossewayperformance.co.uk/e- ... oling-fan/
S1 OTS OSB; S1 FHC ODB
#10 Re: Kenlowe fan and dynamo?
Thanks Tag.
Way down at the southern tip of Africa, Rotherham and the USA are much of a muchness. My guy is a Barratt vendor, making Barratt supplies easier. Things sometimes disappear on their way to us...
Frank
1963 3.8 FHC
1963 3.8 FHC
#11 Re: Kenlowe fan and dynamo?
I did read some rumour somewhere that Kenlowe no longer make fans....although there seem to be plenty out there so maybe an urban myth or fake news as the Donald would say
#12 Re: Kenlowe fan and dynamo?
I can imagine Heuer (David) stalking off in a huff as methinks his interest in those watches is from before they were sullied with that 'Tag'Vonkie wrote:Thanks Tag.
#13 Re: Kenlowe fan and dynamo?
TAG Heuer began as Uhrenmanufaktur Heuer AG, founded in 1860 by Edouard Heuer in St-Imier, Switzerland. In 1985 TAG Group purchased a majority stake in the company, forming TAG Heuer. In 1999 French luxury goods conglomerate LVMH bought nearly 100 percent of the Swiss companyGfhug wrote: I can imagine Heuer (David) stalking off in a huff as methinks his interest in those watches is from before they were sullied with that 'Tag'
Indeed, all my Heuer watches were made between 1968 and 1973 well before TAG got involved. Off to put on my huff and stalk away!
#14 Re: Kenlowe fan and dynamo?
I installed two of the Coolcat-motors (Ser. 1.5) and thy work and look very good.
Buther other than Coolcat claims they draw as much power as the old ones I replaced.
Maybe one of these fancy alternator-dressed-as-dynamo-thingies will be a better solution for a lack of electricity:
https://www.limora.com/en/british-cars/ ... 56527.html
Ser. 1.5 DHC LHD
#15 Re: Kenlowe fan and dynamo?
Thanks Jaglex
As these things go, I am still waiting for various parts to wend their way across the ocean. Retrim being done (assuming kit not also delayed beyond expectation) first week in July. So I still don't have her.
I will have to see how it goes (along with no doubt several other little and not so little foibles). If the heating and/or charging become/s an issue, I shall turn to Kalte Katze and potentially consider an alternator.
Frank
1963 3.8 FHC
1963 3.8 FHC
#16 Re: Kenlowe fan and dynamo?
Jaglex
Rather than pay £750 for that hybrid I suggest you fit a Nippon Denso alternator, details in the Upgrade forum.
#17 Re: Kenlowe fan and dynamo?
Another vote for Kenlowe plus dynamo.
Seven years, 20k miles, day and night use, all seasons. Thought I don't have an electric rear window.
I find the way that the headlights dim at idle charming, and find the way that the ammeter dips into the negative at idle when the fan cuts in a useful indicator that the Kenlowe is working.
1962 FHC 885626
1962 FHC 885626
#18 Re: Kenlowe fan and dynamo?
Delighted with my dynamo and the cool cat fan (purchased from Ken Verity) along with the upgraded heater fan. Also have one of the 500T radiomobile devices with the separate amplifier said to be a real battery drainer - story goes that one pulled off the road into a quite spot in the woods for a 'pleasant picnic' with the radio playing gently in the back ground - 2 hours later! the battery is drained, car won't start. Hopefully will try this one day and put this story to the test!
Chassis no: 860403
DOM - 11th April 1962
#19 Re: Kenlowe fan and dynamo?
Manufacturer/Brand: Radiomobile Ltd., Cricklewood Works, London aka S.Smith and Sons
Model: 500T - Radiomobile Ltd
Year: 1961
Type: Car Radio
Valves: 4: 12AC6 12AD6 12AC6 12AE6
Semiconductors : 2: OC82 OC26
Principle: Super-Heterodyne ZF/IF 470 kHz
Tuned circuits: 7 AM circuit(s)
Wave bands: Broadcast (MW) and Long Wave
Material: Metal case
Shape: Chassis only or for "building in"
Power type and voltage: Storage Battery 12 Volt
Those four valves (tubes) are going to drain the battery very quickly. A valve radio needs two power supplies, a high tension 'B' supply for the circuitry and a low tension 'A' supply for the valve heaters (tube filaments); for the 500T a 'C' supply for the semiconductors is required. The A supply does not drain the battery very much but the high tension B circuitry will quickly deplete the car battery. If you used the radio for 4 hours you would probably not have enough juice to start the car.
Year: 1961
Type: Car Radio
#20 Re: Kenlowe fan and dynamo?
David
The radio is c - - p anyway, will probably get the innards changed for better sound and tuning - looks nice and period!
Chassis no: 860403
