Hello,
I am looking for the dimensions of the boot boards for a roadster S1 or S2, because I would like to reproduce the boards with composite wooden ...
Can anybody please tell me dimensions A, B and C and confirm me that the original thickness is 10 mm ?
Thanks in advance for yours answers.
Jacques
Dimensions of boot floor boards - S1 roadster
#1 Dimensions of boot floor boards - S1 roadster
Jacques
E-type serie 1 OTS 1966.
#2 Re: Dimensions of boot floor boards - S1 roadster
S2 9mm Thickness, A:353, B:616, C:738mm. 7-Ply kind. The bottom rear part of the larger board is chamfered.
Here the dimensions for the metal bracket, semigloss black. The rubbers are the same as used for the tank flap.
Martin
Martin
Martin Scherz
Late S2 1970 OTS US LHD
#3 Re: Dimensions of boot floor boards - S1 roadster
Hello Martin,
Thank you very much for this precise and valuable information.
Best Regards.
Jacques
Best Regards.
Jacques
Jacques
#4 Re: Dimensions of boot floor boards - S1 roadster
For info I had some of the metal boot board supports made in st. steel years ago when I needed one, still have some left in my garage if anyone needs one. They are blank so you would have to drill the holes etc.
#5 Re: Dimensions of boot floor boards - S1 roadster
Hi Dave, can you add one (or however many are needed) to my other order?
Many thanks
Many thanks
#6 Re: Dimensions of boot floor boards - S1 roadster
OK Geoff no problem.
