Door hinges
johnj
#1 Door hinges
Post by johnj » Sun Dec 03, 2017 1:59 am
Re hanging my doors on the series 1 1/2 what are the 2 set screws on the hinges on door side for
Is it some factory alignment puzzled
Thanks in advance
Jeremy
#2 Re: Door hinges
Post by Jeremy » Sun Dec 17, 2017 4:06 pm
The safety strap is fixed on with 2 panhead screws. But AFAICR there are 4 holes so the same hinges can be used the other way up on the other side of the car. Might that be the answer?
Jeremy
1967 S1 4.2 FHC in slowly converging bits
64etype
#3 Re: Door hinges
Post by 64etype » Fri Dec 22, 2017 2:42 pm
I believe they were installed/drilled at the factory to help assure door alignment as the clamping force provided by the four set screws could be less than adequate. I found them to be very helpful with achieving alignment when reinstalling original doors and hinges.
Eric
