Picture of aluminium trim panel below back door
#1 Picture of aluminium trim panel below back door
Does anybody have a picture of the aluminium trim panel that sits below the back door aperture BD20167 on the Series one FHC and possibly the length and height measurements if possible?
None of the usuals appear to supply this trim panel and I would like to make one if at all possible.
Many Thanks,
Many Thanks,
#2 Re: Picture of aluminium trim panel below back door
Hi Paul...on my 69 S2+2 it was a very thin flimsy piece of alloy....cant find a photo but you can see the shape on John Skinners site......unfortunatly for your model it dosnt show it but call them they may supply one http://www.john-skinner.co.uk/jaguar/e- ... 2ltr/#trim Steve
#3 Re: Picture of aluminium trim panel below back door
Hi Steve,
Thanks for the link. the Series One one, appears to have even less shape than the Series two
(5th picture down on the right)
I think half of its height is the vinyl cover.
I would really prefer to make one rather than buy one already covered, if at all possible.
#4 Re: Picture of aluminium trim panel below back door
Let me look tomorrow evening...mine is up in the loft somewhere....
Jonathan
Jonathan
#5 Re: Picture of aluminium trim panel below back door
Hi Paul...saw that photo.....thought it was just a piece of vinyl Steve
#6 Re: Picture of aluminium trim panel below back door
Hello Paul
Found the piece...it’s not a simple rectangle...send me your address and I will trace around it and post you a full size template...it also has to have rivets to hold it in place and an oversize section of vinyl
Jonathan
Jonathan
#7 Re: Picture of aluminium trim panel below back door
Hi Jonathan,
That's very kind of you; I will PM my address.
Yes; according to the parts manual it has 8 rivets; I can only find 6 holes for it though??
Thank You,
Thank You,
#8 Re: Picture of aluminium trim panel below back door
A photo on the forum would good...just a bit more knowledge added....Steve
#9 Re: Picture of aluminium trim panel below back door
I am restoring a 62 E Type FHC and would much appreciate the picture/template dimensions for this panel
Chris
Chris
