I am making the central armrest but i have no dimension about its height ?
I have tested 10 cm for the box without the foam thickness ( between the 2 arrows on the pic below). which seems correct.... for me ! And is it the same in front and rear ?
what is it for your car ?
central arm rest dimensions ?
#1 central arm rest dimensions ?
Looking for a OTS 4.2 serie 1....! and now have found a fhc xk 140
#2 Re: central arm rest dimensions ?
Hi Yves,
My car measurements (approx) are;
Arrow #2 = 75mm (front)
Arrow #1 = 52mm (rear)
1965 S1 4.2 FHC (early)
#3 Re: central arm rest dimensions ?
#4 Re: central arm rest dimensions ?
Taken from a series 1 2+2
Hope they help
The cut out corner is on the back edge bottom corner
Hope they help
#5 Re: central arm rest dimensions ?
Thank's Phil
