Hi all
I’m having trouble finding the rubber bushes that fit between the two washers that the windscreen motor mounting plate is mounted on. There are 3 of them
I cannot find the part not miner anywhere
Can anyone help please?
Robbie
S1 1962 OTS
Rubber bushes on wiper motor mounting plate studs
#1 Rubber bushes on wiper motor mounting plate studs
#2 Re: Rubber bushes on wiper motor mounting plate studs
Try Steve Hunt.
Jeremy
1967 S1 4.2 FHC
1967 S1 4.2 FHC
#3 Re: Rubber bushes on wiper motor mounting plate studs
#4 Re: Rubber bushes on wiper motor mounting plate studs
I used the same ones that mount the rad fan motor C18111 is the part number worked fine.
Hope this helps.
Neal.
Hope this helps.
Neal.
#5 Re: Rubber bushes on wiper motor mounting plate studs
Hi Neal
Thanks for pointing me in the right direction
The Rubber grommet is actually C 18110*
Robbie
Robbie
#6 Re: Rubber bushes on wiper motor mounting plate studs
Oop's sorry Robbie.
Yes you are right my bad typing.
Neal.
Neal.
