final drive unit
listers
Switzerland
#1 final drive unit
Post by listers » Tue Apr 03, 2018 7:27 pm
I have a problem with my final drive unit (differential). It is not possible to pull out the companion flange assembly (Jag item no. 3879). Neither with a polling nor with heating does works.
Thanks Jonas
#2 Re: final drive unit
Post by politeperson » Tue Apr 03, 2018 8:35 pm
You mean the input flange?
Mine would not come off either. I actually bent it and had to buy a new one in the end.
I used the correct puller, heat everything.
James
L.J.K. Setright was right.
