choke warning light
#1 choke warning light
I have a 64 e type and I need help with the choke warning light. The jewel in the holder is mounted in the dash panel, but what holds the socket where the bulb goes in the back of the panel. The socket falls out where the bulb is held in... what actually holds the complete unit together (hard to explain). And, where is the earth ground at on the unit. Have been restoring and am learning as I'm going. Thank you for any help, George.
#2 Re: choke warning light
The jewel and chrome surround pop through the dash and screw into a machined aluminium tube. The other end is wider and a standard MES clip on bulb holder with fingers will clip in. I can't recall where the earth goes but any retaining bold on the bulkhead is fine...or you can retain it behind one of the knurled nuts that hold the tachometer in place....at least that is what is behind mine but others may differ....
#3 Re: choke warning light
Thank you for the information. I'll have to try to find a part # so I can find a mes clip that holds the bulb holder in. Looking... do you know where I can find an MES clip? Or where I can find get the whole assembly #C11724 for a 3.8 '64 Jaguar? Getting down to these smaller restoration parts. Headache
I have a parts book and it doesn't show this clip.
