Early drive shafts
Robbiee
#1 Early drive shafts
Post by Robbiee » Tue May 22, 2018 4:27 am
I’m stripping my early S1 tubular driveshafts.
Can anyone advise as to the function of what appears to be a central pin located in the driveshaft...seems to be held in place with a circlip either end?
Do they need to be removed /serviced for any reason or can I just leave them alone and carry on with replacing the UJs.
BW
Robbie
#2 Re: Early drive shafts
Post by abowie » Tue May 22, 2018 6:45 am
Can you post a photo?
#3 Re: Early drive shafts
Post by mgcjag » Tue May 22, 2018 8:34 am
Hi Robbie...have a look in the factory fit 3.8 section page 10.. here is some info copied from there
Up until about July 1962 half shafts consisted of a steel tube with a yoke welded on either end. There is a 5/16" steel rod running through the centre, secured at each end with a copper washer, a steel washer, and a circlip. Later cars had smaller diameter solid half shafts:
The function of the steel rod is a bit of a mystery but the combination of copper and steel washers suggests it is prepared for rotation of the yoke so is probably a fail safe in case of a fracture in the shaft weld. It would prevent the parts flailing about which could cause major damage:
Images havent copies but you can see them in the factory fit section....Steve
Robbiee
#4 Re: Early drive shafts
Post by Robbiee » Tue May 22, 2018 3:14 pm
Thanks Steve
Very comprehensive
So ..I’ll just leave them alone!
Robbie
